ACL Question
trinawong
Dear All,
I am bit confuse about this kinda of ACL configuration, let's say to prevent 10.10.10.60 ~ 10.10.10.80 hosts traffic pass through serial interface. what wildmask can I use?
Thank you.
Jon Marshall
Well you can't cover this off with one mask but you could do
host 10.10.10.60
host 10.10.10.61
host 10.10.10.62
host 10.10.10.63
host 10.10.10.64 0.0.0.15
host 10.10.10.80
the 10.10.10.64 entry has a wildcard mask of 0.0.0.15 which covers the hosts 10.10.10.64 -> 10.10.10.79
Jon
Edison Ortiz
You will need the following entries
! Deny from 10.10.10.60-63
access-list deny ip 10.10.10.60 0.0.0.3 any
! Deny from 10.10.10.64-71
access-list deny ip 10.10.10.64 0.0.0.7 any
! Deny from 10.10.10.72-79
access-list deny ip 10.10.10.72 0.0.0.7 any
! Deny 10.10.10.80
access-list deny ip host 10.10.10.80 any
! Permit rest of the traffic
access-list 101 permit ip any any
interface sx/x
ip access-group 101 out
HI, [Do Rate ALL HELPFUL HOSTS]
You will need to implement as recommended by Edison.
10.10.10.60 0.0.0.3
Means =
Firs Adr: 10.10.10.60
Last Adr: 10.10.10.63
This way you need to Split the overall Subnet and write Deny Rule then Permit other IP Address because without any permit statements for other IP Ranges the implicit deny will come into Action.
Best Regards,
Guru Prasad R
