Service-policy on Multilink
fashour
I have this following senario:
A multilink logical interface with number of physical interfaces bundled.
There is a service policy applied to the multilink int.
Problem:
when adding or subtracting physical interfaces to the bundle, the service policy disappears.
Is this normal behavior or is this a bug? To me, it looks like a bug but I am not sure. Any advice will be appreciated.
guruprasadr
Level 7
Level 7
HI,
This is interesting.
A interface can run only one Serivce Policy at a time.
>> We will wait for some Expert Advice.
BR,
Guru Prasad R
bvsnarayana03
Level 5
Level 5
I have seen instances when the interfaces that are part of the multilink go down or removed from bundle, then policy-map doesnt work any more. This is the case when sum of Bandwidth configured on policy-map is less than that configured on physical interfaces of Mu bundle. In such cases a message appears as "policy-map xxx suspended".
however, I'm not sure what happens when interfaces are added to bundle.
hope that clarifies.
pls rate all helpful posts.
