ACL to block TFTP not working
stevec90
I am trying to block TFTP traffic with an ACL with the following commands, and have applied it to the appropriate interface (outbound on interface with the server subnet) and I can still copy a file over via TFTP. What am I missing? I have confirmed Solar Winds TFTP server is functioning on UDP port 69.
deny UDP any any eq 69
permit ip any any
Giuseppe Larosa
Hello Steve,
outbound ACLs don't block packets that are generated locally on the router itself.
So if you test the ACL by copying a file from the router itself to the TFTP server the result is an apparent  failure of the ACL = a successful TFTP file transfer.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Steve,
Hope to help
Giuseppe
Thanks for the clarification on that. When I switch to the client on another subnet it works fine.
