QoS class-map match-any
lkadlik
When you create a class map using the match any functionality, does it read the class map from the top down and then stop on the first match it sees or does it look at all the match statements?
For ex
class-map match-any XXX
  match protocol rtp
  match ip dscp ef
  match protocol citrix
policy-map XXY
  class XXX
   priority percent 75
   set dscp default
  class class-default
   fair-queue
   set dscp default
If it finds a match for rtp will it stop looking or if there is traffic for rtp and citrix and the router sees it will it match/tag on both to apply QoS to that traffic?
Thank you
Lynne
Hello Lynn/Jon
to be noted that the same packet cannot be classified (= be a match) for RTP and for citrix at the same time, just for correctness
match -all = logical AND of all conditions   all conditions must be true for a match
match -any = logical OR of all conditions  if at least one condition is true there is a match
Hope to help
Giuseppe
8 Replies 8
Jon Marshall
For ex
  match protocol rtp
  match ip dscp ef
Thank you
Lynne
Lynne
With match-any it reads them in order and stops once/if it finds a match.
With match-all it has to match against all the match statements so it needs to read them all as long as it keeps matching ie. it it doesn't match in one of the match statements there is no need to keep trying to match in the following match statements.
In the above example if there is match for rtp it will stop trying to match against anything else and will not check your other match conditions. So obviously with match-any the order of the match conditions is all important.
Jon
Thank you Jon.  That is very helpful.
Two more questions,  if i want to make sure that all of the items in my class-map are matched on when the appropriate traffic is generated.  Will it work if i create a separate class map for each item I want QoS on and apply each class-map to the policy-map applied?
Also, my understanding of the match-all functionality is that all the items you set to match in a class-map need to be present ( ie traffic) for the policy to be applied.  Is this correct?
Thank you.
Thank you.
Lynne
If you want all of your items in your class-map to be matched then you should use the match-all as you say. Only traffic that then matches all the items within your class-map will pass the test.
Jon
If I did a match-all list and only 2 out of the three items were present (say rtp and citrix) would qos still be applied to the rtp and citrix traffic if nothing is getting tagged for in regards to dscp ef?
Lynne
No it wouldn't. Match-all means just what it says ie. all items must be matched for the relevant policy map entry to be applied.
Jon
Thank you.
No problem, glad to have helped.
Jon
Hello Lynn/Jon
Hope to help
Giuseppe
