ACL works but i dont understand why
hansvanbreen
All our Cisco routers have been configured by an external consultant some years ago, and now i have been assigned the task to maintain these routers (ios novice...)
Each router has two ACL's, one on the wan interface and one on the lan interface. Its the wan ACL, however short, i dont understand...
interface FastEthernet0/0
description LINK_TO_INTERNET
ip address 80.8.5.90 255.255.255.248
ip access-group 100 in
ip nat outside
ip inspect To-Internet out
duplex auto
speed auto
no cdp enable
access-list 100 remark *** anti-spoofing outside -> router ***
access-list 100 deny ip 10.0.0.0 0.255.255.255 any
access-list 100 deny ip any any log
As i understand from this all traffic would be blocked, but internet access works fine.
Who can fill me in on the missing bits and pieces?
Hans
2 Accepted Solutions
Jon Marshall
Hi Hans
This may well be the full access-list. With just an access-list this would do as you would expect and block all traffic.
However this router is running the Firewall feature set (CBAC) by the looks of it. The "ip inspect To-internet out" line is the one that shows this.
So in effect you start off denying anything inbound from outside. if a user on the inside creates a connection out then a dynamic entry is added to the access-list 100 above the deny ip any any line.
Attached is a link for more details on CBAC
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7c5.html#wp1002187
But the access-list also has a deny ip any any in it. So CBAC is the element that allows this access-list to work. Because without CBAC regardless of the IP addresses used in the packets the access-list on the WAN interface would drop ALL packets.
So i would argue to understand how that access-list can deny all traffic which in normal operations without CBAC would drop all traffic as access-lists are not stateful, you have to understand that it is CBAC that allows this to work
Jon
5 Replies 5
jgross
Hello Hans,
this is not the complete config, I think that there are more line in access-list 100.
The lines you pasted:
You use 10.X.X.X for your internal network.
This part of the access list denys incomming packets with a source adress of 10.X.X.X.
This means nobody from the outside can come into the network with a 10.X.X.X Source Adress and pretend to be from the insite of the network.
Try this link:
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml
Bye
Joachim
Jon Marshall
Hi Hans
actually you all are forgetting the order of operations;
the packets coming inbound on the "ip nat outside" interface are not yet destined for the internal networks when the ACL is checked.
The acl is checked (anything to 10 denied, the inside 10 networks are still there external ip's at this point ;)
nat is performed. The inside global addresses the inside local addresses use on the "ip nat outside" are natted back to 10.x.x.x
then the packet is routed towards 10.x.x.x
so the ACL works because 10.x.x.x traffic is NEVER the destination on this nat outside interface.
see
http://www.zdnetasia.com/insight/network/0,39044847,39370302,00.htm
FYI CBAC (inspect) would be way down the line on the order of operations and not be an issue here.
Jon
Jon thanks for your explanation, you hit the nail on the head, and thank you Joachim and jbrunner for your contributions.
Your help is much appreciated.
Hans
