ACLs for NAT and blocking outgoing WAN traffic
bakerjw
Many thanks to the community for tolerating some of my questions and helping me learn more about Cisco routers. Recently, a user helped me to get NAT running on our router using a single IP address on
GigbitEthernet0/0/0
to a corporate network. For access to the NAT. we use an ACL to permit specific IP ranges to use the NAT. It works as expected. Great!
What I did not expect to encounter was IP ranges that do not use NAT are sending their private IP address through the port that is connected to a corporate network. I really want to block this traffic.
The ACL for allowing subnets to use NAT is NAT_Access
I also created an ACL named
Deny_Firewall_Access
for blocking access out the
GigabitEthernet0/0/0
port.
For testing, I have
192.168.12.0/24
configured for NAT and
192.168.8.0/24
configured to not use NAT.
The pertinent sections of our running configuration is as shown here.
interface GigabitEthernet0/0/0
ip address 123.123.123.27 255.255.255.0
ip nat outside
negotiation auto
spanning-tree portfast disable
interface Vlan108
ip address 192.168.8.1 255.255.255.0
ip helper-address 192.168.0.3
interface Vlan112
ip address 192.168.12.1 255.255.255.0
ip nat inside
ip default-gateway 123.123.123.1
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/1
ip forward-protocol nd
ip nat pool NAT_Pool 123.123.123.27 123.123.123.27 prefix-length 24
ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
ip nat inside source list NAT_Access pool NAT_Pool overload
ip access-list extended Deny_Firewall_Access
10 deny ip 192.168.8.0 0.0.0.255 any
20 permit ip 192.168.12.0 0.0.0.255 any
ip access-list extended NAT_Access
10 permit ip 192.168.12.0 0.0.0.255 any
20 deny ip 192.168.8.0 0.0.0.255 any   <--- Not really needed as I have seen
route-map track-primary-if permit 1
match ip address 197
set interface GigabitEthernet0/0/0
I did try using the
Deny_Firewall_Access ACL
to block access out the
port with this configuration but it interfered with NAT.
ip address 161.218.133.27 255.255.255.0
ip nat outside
ip access-group Deny_Firewall_Access out
negotiation auto
I assume that I am missing some concept or running down the wrong rabbit hole.
Guidance is appreciated.
Hello
Nat is primarily used to "hide" networks, as such if you do not need to hide a certain network then you can negate it from being natted as you noticed in your testing
example:
10 deny ip 192.168.8.0 0.0.0.255 any <this will not nat and allow traffic from this subnet to be routed normally)
So If you wish for the network not to be natted also not to be routed, then just do not advertise it externally
Lastly looking at your configuration, you seem to have added additional
nat/route-map
statements that do not related to any acl, plus you need a
default route
and not an
ip default-gateway
, and you show two different wan ip addressing for the same interface?
match ip address 197 < no acl 197 exists?
no ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload < not required
ip address 161.218.133.27 255.255.255.0  < ???
ip address 123.123.123.27 255.255.255.0  < ???
no ip default-gateway 123.123.123.1
ip route 0.0.0.0 0.0.0.0 gigabitEthernet0/0/0 123.123.123.1 (or)  161.218.133.x
Kind Regards
Paul
7 Replies 7
Sorry dont get what you want here.
Which prefix you dont want to NATing ?
bakerjw
We want
192.168.12.0/24 to NAT out GigabitEthernet0/0/0.
We want to block
192.168.8.0/24
packets from going out
Can you share
Show ip access-list
 After you
ping
from .8.0 subnet
bakerjw
Most certainly.
The ACL
is in the configuration but not being used at the moment.
cisco-c1111-8p-01#show ip access-lists
Extended IP access list CISCO-CWA-URL-REDIRECT-ACL
100 deny udp any any eq domain
101 deny tcp any any eq domain
102 deny udp any eq bootps any
103 deny udp any any eq bootpc
104 deny udp any eq bootpc any
105 permit tcp any any eq www
Extended IP access list Deny_Firewall_Access
10 deny ip 192.168.8.0 0.0.0.255 any (7 matches)
20 permit ip 192.168.12.0 0.0.0.255 any (60 matches)
Extended IP access list NAT_Access
10 permit ip 192.168.6.0 0.0.0.255 any
20 permit ip 192.168.7.0 0.0.0.255 any
30 permit ip 192.168.9.0 0.0.0.255 any
40 permit ip 192.168.12.0 0.0.0.255 any
50 permit ip 192.168.100.0 0.0.0.255 any
60 permit ip 192.168.101.0 0.0.0.255 any
70 permit ip 192.168.104.0 0.0.0.255 any
80 permit ip 192.168.105.0 0.0.0.255 any
90 permit ip 192.168.255.0 0.0.0.255 any
100 deny ip 192.168.8.0 0.0.0.255 any
Extended IP access list meraki-fqdn-dns
any (7 matches)
This 7 matches meaning acl is work
But to be more sure add log to each line and check the log message appear when
ping
from .8.0 subnet
Hello
example:
nat/route-map
default route
and not an
ip default-gateway
Kind Regards
Paul
Once again, Paul. You have been quite helpful.
These statements that you mentioned were added by web interface wizards and have been removed. Sometimes newbies are at the mercy of a GUI until we know better.
nat/route-map
default route
and not an
ip default-gateway
