ASR1001-X 10G port license
Hi all,
I want to order ASR1001-X with license for 10Gbps routing traffic ( FLSA1-1X-5-10G ). I need one 10GE port.
Do I need to order license FLSA1-BIN-1X10GE to enable 10G port?
Is there any chance that maybe one 10GE license is included If I upgrade to 10Gbps?
I know that licenses for 10GE ports are included if I upgrade to 20G:
"ASR1001-X bulit-in 10GE ports are turned on using port-based licenses. However, if the ASR1001-X is upgraded to 20G, then the two built-in ports are automatically included. Please see Table 37 for the Product Numbers of the port and throughput licenses."
Aleksandar
5 Replies 5
Hi Alex, as you mentioned you would need to order the license to enable the 10G port. as for the inclusion with the 10Gpbs im not sure if this is possible. hope to hear from you soon!
Hello Cisco community,
Can I installed the following 2x licenses for 1 ASR-1001x     2 x  FLSA1-BIN-1X10GE
The license is already installed, the router will only install a license once? or can I do both ?
Index 33 Feature: interface_10g
        Period left: Life time
        License Type: Permanent
        License State: Active, Not in Use
        License Count: 1/0/0  (Active/In-use/Violation)
Your help is much appreciated,
JM
make 10g interface no shut
regards
saravanan
Hello Everyone,
I have a similar issue with my ASR1001-X. The 20GBPS licence has been installed but the 10GB ports are still on evalRightToUse
Period left: 8 weeks 3 days
Period Used: 5 minutes 28 seconds
License Type: EvalRightToUse
License State: Active, In Use
License Count: 2/0 (In-use/Violation)
License Priority: Low
Index 30 Feature: throughput_10g_to_20g
Index 31 Feature: throughput_20g
License Type: RightToUse
License Count: Non-Counted
I also have that:
*Jun 7 10:15:38.788: %IOSXE_THROUGHPUT-6-LEVEL: Throughput level has been set to 20000000 kbps
*Jun 7 10:23:13.130: %LINK-5-CHANGED: Interface TenGigabitEthernet0/0/0, changed state to administratively down
*Jun 7 10:23:13.141: %LINK-5-CHANGED: Interface TenGigabitEthernet0/0/1, changed state to administratively down
*Jun 7 10:23:14.130: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet0/0/0, changed state to down
*Jun 7 10:23:14.141: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet0/0/1, changed state to down
How should I do to activate the 2 10GB ports permanently, please?
Thank you very much!
Kind Regards,
RG
Hello Regis Garde,
It's been a while but was wondering if you were able to bring up the interfaces up with the command "no shut"  or was there anything else that needed to be done. (configuration)     would Appreciate a response.   Thank you.
