activate permanent smart License router c1121-8p
midence11
good, I have a problem with a router C1121-8p at the time of activating the permanent license I can not find how to do it, but if what I did was reserve it for that computer but I still do not get to use it permanent, if I could help to be able to activate it permanently the SecurityK9. Thanks in hand.
5 Replies 5
Rich R
- What version of IOS are you using?  I'd recommend 17.6.4 as a minimum.
- Have you configured the "license boot level"?
- What IOS image are you running?  Your license is for NPE so it will only work on NPE image.
eg: c1100-universalk9_npe.17.06.04.SPA.bin not c1100-universalk9.17.06.04.SPA.bin
- Cisco IOS XE Software, Version 17.02.02
- when i use the boot level i see this
Ro_Prueba_2(config)#license boot level securityk9
License Configuration for feature securityk9 is not accepted due to unavailability of the license in SLR mode
*Jan 30 15:12:14.091: %PARSE_RC-4-PRC_NON_COMPLIANCE: `license boot level securityk9 '
Rich R
As I already said I'd recommend 17.6.4 as a minimum!  And then no more SLR.  Smart licensing before SLUP was a MESS.  It's still not great but I've found it mostly works ok in 17.6.4.
You didn't answer the question about what IOS image you're running?
Can you guide me where I can download the latest software?
this version
System image file is "bootflash:c1100-universalk9.17.02.02.SPA.bin"
Ro_Prueba_2#sh version
Cisco IOS Software [Amsterdam], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9-M), Version 17.2.2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 17-Sep-20 16:48 by mcpre
Rich R
https://software.cisco.com/download/home/286315006/type/282046477/release/Bengaluru-17.6.4
Cisco ISR 1100 Series IOS XE Universal-No Payload Encryption
