Active/Active ISP on single router
Ali Bahnam
Dears,
Good day,
Kindly I have cisco 2921 router and I have two ISP (Internet connection) my isuue is how I can configure the router to provide Active/Active Internet connections or do load balancing between the ISPs.
Appreciate your support,
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Given the little inforamation you've provided about your setup and/or exactly what kind of load balancing you're trying to achieve, the following might be all you need (might not too).
ip route 0.0.0.0 0.0.0.0 x.x.x.x name ISP1
ip route 0.0.0.0 0.0.0.0 y.y.y.y name ISP2
