Active active load balancing between 2 ports of ISR4221/K9
Is it possible to configure active-active load balancing between 2 ports of 4221 router? Both the routers are connected via VPN tunnel (P2P connection).
15 Replies 15
No.
Each router has 2 tunnels. If one goes down then other one becomes active.
Connectivity is like ILL is terminated over R1.
R2 is connected to R1 with 2 P2P connections. Both the links are from different ISPs. There is no ILL on R2.
Configuration part:
Auto failover configuration is running on R1.
There are 2 VPNs between R1 and R2.
