Add command to persistent db failed. File system full
lcaruso
Level 6
Level 6
I'm using persistent logging and getting the file system full error message, but I don't see where I'm anywhere near full
Here's the relevant configution detail...
archive
log config
  logging enable
  logging persistent auto
  notify syslog contenttype plaintext
  hidekeys
Here is what happened...
router(config-cmap)#exit
config log persistent auto - Add command to persistent db failed. File system full
router(config)#exit
router#wr
Building configuration...
[OK]
router#sh flash
-#- --length-- -----date/time------ path
4            0 Jul 23 2011 19:03:22 -05:00 syslog
5          660 Jul 24 2011 18:36:44 -05:00 vlan.dat
12         670 Jul 30 2011 13:16:50 -05:00 syslog/log_20110730-131650
94883840 bytes available (33300480 bytes used)
Any help is appreciated. Thanks.
Peter Paluch
Can you please indicate your device platform and the IOS version? Also, please include the dir nvram: output. Thank you!
Best regards,
Peter
Hi Peter,
This is a 887VA running 15.2(1)T
I managed to work around this by clearing the entries with
clear archive log config force
clear archive log config persistent
and then increasing the number of entries from the default of 100 to 1000
archive
log config
  logging size 1000
Larry
Here's nvram...
Directory of nvram:/
  245  -rw-        5663                      startup-config
  246  ----        3555                      private-config
  247  -rw-        5663                      underlying-config
    1  -rw-        2945                      cwmp_inventory
    4  ----         117                      persistent-data
262136 bytes total (248770 bytes free)
