OSPF reconvergence after fail over
Dennis Mink
I am implementing a solution for for a customer that has dual WAN links for redundancy. In order to achieve this (and for security purposes) I have implemented 2 OSPF processes (one of which is a on a VRF).
The subnet that I am testing for fail over is 10.233.20.0/24.  under normal circumstances that route is in the routing table in OSPF 1:
N_Primary#sh ip route 10.233.20.0
Routing entry for 10.233.20.0/24
  Known via "ospf 11", distance 110, metric 110
  Tag Complete, Path Length == 1, AS 65031, , type extern 1
  Last update from 10.133.1.250 on Ethernet0/3, 00:04:14 ago
  Routing Descriptor Blocks:
  * 10.133.1.250, from 10.133.1.250, 00:04:14 ago, via Ethernet0/3
      Route metric is 110, traffic share count is 1
      Route tag 3489725959
When I fail the primary link, the secondary link kicks in using OSPF11 to populate the routing table  (higher metric of 110)
NOC_Primary#sh ip route 10.233.20.0
  Known via "ospf 11", distance 110, metric 4010
  Last update from 10.133.1.250 on Ethernet0/3, 00:01:13 ago
  * 10.133.1.250, from 10.133.1.250, 00:01:13 ago, via Ethernet0/3
      Route metric is 4010, traffic share count is 1
As can be seen below, both processes have the 10.233.20.0 subnet in their DB, with different metrics as the only difference
N_Primary#sh ip ospf 11 database external 10.233.20.0   (FROM SECONDARY)
            OSPF Router with ID (10.133.1.254) (Process ID 11)
                Type-5 AS External Link States
  Routing Bit Set on this LSA
  LS age: 98
  Options: (No TOS-capability, DC)
  LS Type: AS External Link
  Link State ID: 10.233.20.0 (External Network Number )
  Advertising Router: 10.133.1.250
  LS Seq Number: 80000001
  Checksum: 0x4DCD
  Length: 36
  Network Mask: /24
        Metric Type: 1 (Comparable directly to link state metric)
        TOS: 0
        Metric: 4000        <-------------------------HIGHER METRIC
        Forward Address: 0.0.0.0
        External Route Tag: 3489725959
N_Primary#sh ip ospf 1 database external 10.233.20.0     (FROM PRIMARY LINK)
            OSPF Router with ID (10.133.2.1) (Process ID 1)
  LS age: 1120
  Advertising Router: 10.133.0.2
  Checksum: 0x623D
  Length: 36
  Network Mask: /24
        TOS: 0
        Metric: 1   <--------LOWEST, MOST PREFERRED
        External Route Tag: 65530
The problem is that when bring the PRIMARY link back up, the routing table on my router, will not converge back to the original route with the cheaper metric.
Not even after the 30 minute periodic LSA recomputation interval. Any suggestions on how to force fall back to the more favourable route with the lower metric to the primary WAN?
Please remember to rate useful posts, by clicking on the stars below.
Please check the following link:
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080531fd2.shtml#topic2
It explains about redistribution between two ospf processes.
Your problem is quite similar and has to with the administrative distance.
Perhaps it wil work when you reduce the AD on opsf process 1.
regards,
Leo
5 Replies 5
lgijssel
Level 9
Level 9
Perhaps I understand you wrong but from the output provided it looks different:
regards,
Leo
You are spot on, I pasted the wrong output in.
so in normal scenario when Primary WAN is up, the route should show the following:
  Known via "ospf 1", distance 110, metric 21
  Tag 65530, type extern 1
  Last update from 10.133.2.125 on Ethernet0/0.102, 00:00:08 ago
  * 10.133.2.125, from 10.133.0.2, 00:00:08 ago, via Ethernet0/0.102
      Route metric is 21, traffic share count is 1
      Route tag 65530
regards,
Leo
Thanks mate, I had it fixed, before i read your post but you are spot on again, I changed the AD of one of the processes to 120 and now fail over and fall back are working properly.
I guess with fall back, although the primary link re-populates OSPF 1 , it will keep the original route even though new LSA's occurr, the LSA's from one process are not taken into account into another process, tweaking the AD changes that behaviour.
Thanks again
Leo,
Exactly. I've just made a simple three router scenario where two routers advertised the same external network to the third one, having a different total metric. The routing table on the third router always contained the first advertised alternative, and was removed (and replaced) only if the original route became unreachable. The metric did not have any influence - modifying the administrative distance solved this.
Good point!
Best regards,
Peter
