Add Route Switch Processor 720 as Standby
Hello Dear,
I have a 7606 Router with single Route Switch Processor 720 at the chassi works as active RP ( Route Processor ). Can I add another RP to the chassis as standby incase of fialure of the first RP ?
your reply is much appreciated.
Ahmed
34 Replies 34
Hi Ahmed,
Can you collect and attach crashinfo files?
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi Ivan,
I have attached the crash file.
Thanks in advance for your offered help.
Ahmed
Hi Ahmed,
This crash file is from SP and shows that RP was the culprit and crashed first:
Aug  1 18:47:27.333: SP: SP detected RP/Draco rebooting, resetting SP
=== Start of Crashinfo Collection (21:47:27 UTC Thu Aug 1 2013) ===
Check for another crashinfo files on RP (bootflash).
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Cisco 7606S with dual RSP720-3C-GE 2 engines
Both running same IOS and package files.
Both Config Registers are as follows:
The only difference that I see are Modules 5 & 6 Revision numbers are different and the Bootstrap loader is different on each device.  See Below..
When performing the "redundancy force-switchover" command the device fails over to the Hot Standby, but the original master goes into ROMMON
NAME: "module 5", DESCR: "RSP720-3C-GE 2 ports Route Switch Processor 720 Rev. 5.9"
PID: RSP720-3C-GE , VID: V09, SN: JAE142704O2
OID: 1.3.6.1.4.1.9.12.3.1.9.29.51
NAME: "msfc sub-module of 5", DESCR: "7600-MSFC4 C7600 MSFC4 Daughterboard Rev. 1.5"
PID: 7600-MSFC4 , VID: 000, SN: JAE142702DZ
OID: 1.3.6.1.4.1.9.12.3.1.9.17.72
NAME: "switching engine sub-module of 5", DESCR: "7600-PFC3C Policy Feature Card 3 Rev. 1.2"
PID: 7600-PFC3C , VID: 000, SN: JAE14260QP8
OID: 1.3.6.1.4.1.9.12.3.1.9.17.94
NAME: "module 6", DESCR: "RSP720-3C-GE 2 ports Route Switch Processor 720 Rev. 5.2"
PID: RSP720-3C-GE , VID: V09, SN: JAE1211B8A6
NAME: "msfc sub-module of 6", DESCR: "7600-MSFC4 C7600 MSFC4 Daughterboard Rev. 1.1"
PID: 7600-MSFC4 , VID: 000, SN: JAE1211B7HV
NAME: "switching engine sub-module of 6", DESCR: "7600-PFC3C Policy Feature Card 3 Rev. 1.1"
PID: 7600-PFC3C , VID: 000, SN: JAE1211B85M
Do the RSP system bootstrap versions have to match in order for sso redundancy switch over to work correctly?  Everytime I power cycle my Cisco 7606S device the Master RSP boots up just fine but the Hot Standby does not.
I have verified that both RSP's have the same IOS c7600rsp72043-advipservicesk9-mz.153-3.S6.bin, same amount of memory etc.  The only difference that I can determine are that the bootstrap versions are different.
