Add Std ACL
chrissnop
hi guys, how to add an ACL to the existing ACL configuration?
Example, i have this one:
Standard IP access list 1
10 deny 11.12.13.14
20 permit any (52181890 matches)
I want to add another deny IP.
Can I just simply add like this:
access-list 1 deny host 6.7.8.9
Thanks.
2 Accepted Solutions
Mark Malone
Hi do ip access-list standard 1 11 deny host 6.7.8.9 exit conf t ip access-list resequence 1 10 10 exit sh ip access-lists 1
The re-sequence command is optional I just use it to keep acls tidy and in blocks of 10s so you always have room to insert more lines if required , some acls can grow to be hundreds of lines long , you can still just put a line in between say 10 and 20 you don't have to re-sequence if you don't want to
And yes it should work all it does it changes it and fits in in blocks of 10
7 Replies 7
Mark Malone
Thank you, Mark.
Cheers!!!
Hi guys, thank you for your help.
Just another question:
    10 deny   1.12.13.14
    20 deny   2.15.16.17
    30 deny   3.18.19.20 (21 matches)
    40 permit any (83965005 matches)
So I added the 2 IP Addresses, if I need to add another one, can it be done like this:
The number "13" is for the new block IP:
 ip access-list standard 1 13 deny host 5.10.20.30 exit
But how about the re-sequence command, will the command below work?
Thanks.
Thanks Mark, I thought it was required. Thanks again for the heads up. Cheers!!!  🙂
Pawan Raut
Level 10
Level 10
If you want any acl statement on top then use
ip access-list standard 1 1 deny xxxxx
Thanks, Pawan.
