Adding additional block of public IP's to UC540 WAN
stewardgs
I am trying to add additional block of 4 public IP address to UC540.
When trying to create NAT pool, i am receiving error the new range is not in the same subnet as WAN.
Current WAN subnet is /30, but new block of IP's change after first 2 octets.
Obviously if we change WAN subnet, the connection drops.
Any suggestions on how to add this range to the UC540. Additional IP's are only being used for 1 to 1 NAT
Thanks in advance
Guy
Julio Carvajal
Nop, that's a requirement for a NAT pool bud,
I have seen this behavior on the last code of some of the Cisco devices such as the ASA but due to customer requests they have changed so the ASA can be configured with the desing in mind you are looking for.
For the UC540 this is not possible (yet) so the only solution is what you suggested bud
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
