06-13-2008 12:47 PM - edited 03-03-2019 10:21 PM
Under the router rip command you can add an offset to a received route using the offset command and an ACL. Is there a command you can add to an interface so that all advertisements it sends are already modified with a weight or hop count or some type of offset?
Diego
Solved! Go to Solution.
06-13-2008 01:44 PM
Diego
Using the offset command under the "router rip" configuration there are optional paramneters to specify an interface. So if you want to offset routes received/sent on a a particular interface you can specify this in your offset list. See link for details:
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfrip.html#wp1017883
Does this answer your question ?
Jon
06-13-2008 01:44 PM
Diego
Jon
06-16-2008 04:31 AM
Yes, thank you very much. Don't know what I hadn't seen the interface option. Maybe I was using an older IOS that doesn't support that.
Thanks again,
Diego
