04-09-2018 03:53 PM - edited 03-05-2019 10:14 AM
I'm managing several devices that are using VRF lite. All works fine for VTY access, until I add a PAT statement within the VRF. Sanitised config as follows:
router-aart#sh run Building configuration... version 15.2 service nagle no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname router-aart ! boot-start-marker boot-end-marker ! ! vrf definition InVRF rd 192.168.0.0:666 ! address-family ipv4 exit-address-family ! ! logging buffered 51200 enable secret 5 <removed> ! aaa new-model ! ! aaa authentication login default local aaa authentication login vpnuser local aaa authentication ppp default if-needed aaa authorization exec default local ! ! ! ! ! aaa session-id common clock timezone 6 0 ! ip cef ! ! ! ip dhcp pool site-InVRF vrf InVRF network 192.168.0.0 255.255.255.0 dns-server 196.168.1.1 8.8.8.8 default-router 192.168.0.254 lease 7 ! ! ! ip domain name InVRF.com ip name-server 8.8.8.8 ip name-server 8.8.4.4 no ipv6 cef ! multilink bundle-name authenticated ! ! ! ! ! ! ! hw-module pvdm 0/0 ! ! ! ! redundancy ! ! ! ! ! ip ssh time-out 60 ip ssh authentication-retries 2 ip ssh version 2 ! ! crypto isakmp policy 1 ! crypto isakmp policy 2 ! crypto isakmp policy 10 crypto isakmp key x address y crypto isakmp key a address b crypto isakmp invalid-spi-recovery ! ! crypto ipsec transform-set blah <removed> mode tunnel ! ! ! crypto map crypto-vpn 10 ipsec-isakmp description VPN to blah set peer w.x.y.z set transform-set blah match address xxx crypto map crypto-vpn 20 ipsec-isakmp description VPN to feh set peer a.b.c.d set transform-set blah match address yyy ! ! ! ! ! interface GigabitEthernet0/0 description LAN no ip address load-interval 30 duplex auto speed auto ! interface GigabitEthernet0/0.10 description InVRF LAN encapsulation dot1Q 10 vrf forwarding InVRF ip address 192.168.0.254 255.255.255.0 no ip redirects ip accounting output-packets ip nat inside no ip virtual-reassembly in ! interface GigabitEthernet0/0.20 description Local encapsulation dot1Q 20 ip address 192.168.2.254 255.255.254.0 no ip redirects no ip proxy-arp ip accounting output-packets ip nat inside no ip virtual-reassembly in ! ! interface GigabitEthernet0/1 desc link for InVRF vrf forwarding InVRF ip address 1.2.3.1 255.255.255.252 ip nat outside no ip virtual-reassembly in ip tcp adjust-mss 1452 load-interval 30 duplex auto speed auto crypto map crypto-vpn ! ! interface GigabitEthernet0/0/0 description Other Link ip address dhcp ip nat outside ip virtual-reassembly in load-interval 30 duplex auto speed auto ! ip forward-protocol nd ! no ip http server no ip http secure-server ! no ip nat service sip udp port 5060 ip nat inside source list local-net interface GigabitEthernet0/0/0 overload ip nat inside source list InVRF-NAT interface GigabitEthernet0/1 vrf InVRF overload ip nat inside source static tcp 192.168.0.20 554 1.2.3.1 554 vrf InVRF extendable ! ip route 0.0.0.0 0.0.0.0 dhcp ! ip access-list extended InVRF-NAT permit ip 192.168.0.0 0.0.0.255 any ip access-list extended local-net permit ip 192.168.2.0 0.0.0.255 any ! access-list 110 permit ip host 4.4.4.4 any ! access-list 110 has all management hosts permitted to access this device ! ! ! ! mgcp profile default ! ! ! ! ! gatekeeper shutdown ! ! banner motd ^C ^C ! line con 0 logging synchronous line aux 0 line 2 no activation-character no exec transport preferred none transport input all transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1 line vty 0 4 access-class 110 in vrf-also login authentication local transport input telnet ssh line vty 5 15 access-class 110 in vrf-also login authentication local transport input telnet ssh
Everything worked perfectly until I put in
This is not the first time i've seen it, but as i'm using VRF Lite with increasing frequency to manage devices with multiple WAN links, i'd like to fix it. This has been on all versions of 15.1 on 29xx and 39xx's.
Any advice appreciated.
08-19-2019 06:59 AM
