Adding route-map gives an alert !
sebastien3
Level 4
Level 4
On 4500-X I add a route-map :
route-map set-LOCALPREF permit 10
set local-preference 300
In the console I see the following message once the route-map is added : *Mar 24 08:11:42.623: entryalert!
Any idea why this is creating an alert ?
Harold Ritter
Hi @sebastien3 ,
This is just an informational message. It has no impact on functionality or performance. You can just ignore it.
THANKS ! But it doesn't seem normal... This is the first time I've seen the message, it's confusing !
No message on 3750-X or routers, only on 4500-X
It is not normal indeed. It is a cosmetic bug.
