adding security to wireless network
Ed Lo
Level 2
Level 2
I have 2 wireless networks and want to add a password to 1 of them. I've tried doing it on my own and when I try to connect it says 'cannot connect to network'. Below is how I've been doing this, what am I doing wrong?
dot11 ssid test1
vlan 2
authentication key-management wpa
wpa-psk ascii 7 pass33
interface dot11 0
encryption vlan 2 mode ciphers tkip
thank you
Dean Romanelli
Level 8
Level 8
If you are using vlan 2 and vlan 1 is your native vlan and the vlan where the other wireless network is configured on, then you need to create subinterfaces on the radio and ethernet interfaces on the AP, trunk the port on the switch connecting to your AP and allow vlan 1 & 2 over it, and add the SSID's to the radio interface configs.  Also, if this AP is broadcasting multiple SSID's, you need the mbssid command under radio interface, as well as under both SSID's. Make sure you are permitting vlan 2 over all trunk links to your gateway as well.
See below example and pay close notes to bold sections: (Note: Converting to sub-interfaces can cause service interruptions. Plan maintenance window or set scheduled reload if you hose the AP)
dot11 ssid test1
   vlan 2
   authentication open
   mbssid guest-mode
   wpa-psk ascii pass33   <--- make sure you enter this command WITHOUT the 7 before the PW
dot11 ssid otherwifi
   vlan 1
   authentication open
   mbssid guest-mode
   wpa-psk ascii <what-ever-the-working-one-is>
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 1 mode ciphers tkip
 ssid otherwifi
 ssid test1
 antenna gain 0
 stbc
 mbssid
 station-role root
 no cdp enable
 no shut
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 no shut
interface Dot11Radio0.2
 encapsulation dot1Q 2
 no ip route-cache
 bridge-group 2
 bridge-group 2 subscriber-loop-control
 bridge-group 2 spanning-disabled
 bridge-group 2 block-unknown-source
 no bridge-group 2 source-learning
 no bridge-group 2 unicast-flooding
 no shut
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no shut
interface GigabitEthernet0.1
 no ip route-cache
 bridge-group 1
 no shut
interface GigabitEthernet0.2
 no ip route-cache
 bridge-group 2
 no shut
Switchport connecting to this AP:
switchport mode trunk
switchport trunk allowed vlan all
switchport trunk native vlan 1
