05-28-2020 03:52 AM
Hi All ,
What is the purpose of address-family ipv4 under BGP and also under neighbor on nexus 7k.
If You i remove address-family ipv4 from bgp then what kind of impact would be there .
example nexus 7k switch
router bgp 10
router-id x.x.x.x
address-family ipv4 unicast --- If i remove this command then what would be the impact .
network x.x.x.x
network y.y.y.y
neighbor a.a.a.a remote-as 11
05-29-2020 06:21 AM
explained in this post
Now, the address-family ipv4 declares neighbors with whom we want to exchange normal IPv4 unicast routes. This may be surprising because to exchange IPv4 routes with a neighbor, it is sufficient to simply define that neighbor by its address. The fact is that for backward compatibility with older BGP versions that have not been multiprotocol-capable, the BGP implicitly assigns all defined neighbors to an invisible address-family ipv4 section. In other words, as soon as you define a neighbor, it is automatically being added to an invisible address-family ipv4 section so that you don't have to do it manually.
05-29-2020 06:39 AM
Thank you Pieterh for the reply and info.
Yes you are correct , traditional cisco router and L3 switches have address-family ipv4 unicast as invincible .But on nexus 7ks we have to enter into address-family ipv4 unicast prior configuring network / neighbor statements.
My question is , if we remove address-family ipv4 unicast command from BGP on nexus 7k , what would happen to BGP routes and states ?
Router bgp 10
no address-family ipv4 unicast - If I remove it from nexus 7k switch what would be the impact to bgp routes /states
network 10.x.x.x /24
network 20.x.x.x/24
neighbor x.x.x.x remote-as 11
05-29-2020 08:04 AM
Hello @kmothukuri ,
if NX-OS is more similar to IOS XR that is strictly hierarchical, the impact would be huge and you would torn down the BGP sessions when removing address-family ipv4 unicast or the parser will prompt you that there are established peers.
I would suggest to avoid any change for safety. The configuration is easily readable with address-family ipv4 unicast.
Hope to help
Giuseppe
