Natting with outside interface in VRF
rasmus.elmholt
Level 7
Level 7
HI everyone
I have already read this document: https://community.cisco.com/t5/security-documents/nat-with-vrf-ios-vs-ios-xe/ta-p/3156555#toc-hId--753550695
But cannot get it to work.
I have the following setup, with R10 as a client and R8 as the router doing the NAT from eth0/1 in GR and e0/0 in VRF WAN.
vrf definition WAN
 rd 65000:1
 address-family ipv4
 exit-address-family
interface Ethernet0/0
 vrf forwarding WAN
 ip address 80.1.8.8 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
interface Ethernet0/1
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
ip nat inside source list 1 interface Ethernet0/0 vrf WAN overload
ip route 0.0.0.0 0.0.0.0 Ethernet0/0 80.1.8.1
ip route vrf WAN 0.0.0.0 0.0.0.0 Ethernet0/0 80.1.8.1
access-list 1 permit 192.168.0.0 0.0.0.255
And when I ping from the client or R8s LAN interface the packet(according to Wireshark) gets translated. but the reply does not get back.
R8#ping vrf WAN 80.1.8.1
Sending 5, 100-byte ICMP Echos to 80.1.8.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
R8#ping 80.1.8.1 sou eth0/1
Packet sent with a source address of 192.168.0.1
Success rate is 0 percent (0/2)
What am I missing.
If I added:
ip route vrf WAN 192.168.0.0 255.255.255.0 192.168.0.2 global
I got it to work but only for 192.168.0.2 client. and not for the rest.
Change it all up and configured it with VASI and then it worked right away...
Hello
Two options:
1) Add eth0/1 into the vrf WAN
int eth0/1
ip vrf forwarding WAN
or
2) Add a couple of statics so the global/vrf route tables are aware of each others interface and remove the dynamic nat statment from the VRF WAN as this subnet to be natted isnt in any vrf
no ip route vrf WAN 0.0.0.0 0.0.0.0 Ethernet0/0 80.1.8.1
ip route vrf WAN 0.0.0.0 0.0.0.0 Ethernet0/0 80.1.8.1 global
ip route 8.1.8.8 255.255.255.255 Ethernet0/0
no ip nat inside source list 1 interface Ethernet0/0 vrf WAN
Kind Regards
Paul
If I added:
Hello
@rasmus.elmholt wrote:
If I added:
Well you really wouldn’t have end node subnet directly connected to a rtr, In reality it would be a L3 interface of that subnet where all hosts are reachable behind it , like a L3 switch so that staitic route points to the switches L3 interface as a next hop for all hosts
Kind Regards
Paul
