ADSL 877W issue. ATM interface keeps dropping
achalante
I have a little problem. I configured an ADSL 877W. After it was plugged in, the dialer interface negotiated its IP address ok, but after a few minutes, the atm interface started flapping. It flapped a couple of times, then i lost the IP address. It never picked up an IP address again. I did a couple of debugs, and i couldnt find any errors. The router was replaced with a netgear router, and it worked fine. I replaced the ADSL 877W with a brand new one, and i still experienced the same issue. Please help. My config is as follows:
EASTERN_REGION#sh run
ip cef
ip dhcp excluded-address 192.168.10.1 192.168.10.20
ip dhcp pool XXX_POOL
network 192.168.10.0 255.255.255.0
dns-server 192.168.10.1
default-router 192.168.10.1
domain-name fmb.co.uk
ip domain name yourdomain.com
ip name-server yy.yy.yy.yy
ip name-server xx.xx.xx.xx
crypto pki trustpoint TP-self-signed-978332037
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-978332037
revocation-check none
rsakeypair TP-self-signed-978332037
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key uqef23fr923fg address xx.xx.xx.xx
crypto ipsec transform-set headoffice esp-des esp-md5-hmac
crypto map headoffice 10 ipsec-isakmp
set peer xx.xx.xx.xx
set transform-set headoffice
match address 101
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
dsl enable-training-log
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
no ip route-cache cef
no ip route-cache
encryption vlan 1 key 1 size 40bit 0 1234567890 transmit-key
encryption vlan 1 mode wep mandatory
ssid FMB_WLAN
vlan 1
authentication open
guest-mode
world-mode dot11d country GB both
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
no snmp trap link-status
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xx.xx.xxxx@lanz.broadband
ppp chap password 0 Change
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 102 interface Dialer1 overload
ip nat inside source route-map nonat interface Dialer1 overload
access-list 24 permit xx.xx.xx.xx
access-list 24 permit 192.168.0.0 0.0.255.255
access-list 23 permit xx.xx.xx.xx
access-list 23 permit 192.168.0.0 0.0.255.255
access-list 101 permit ip 192.168.10.0 0.0.0.255 192.168.250.0 0.0.0.255
access-list 102 deny ip 192.168.10.0 0.0.0.255 192.168.250.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map nonat permit 10
match ip address 102
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 24 in
privilege level 15
password $$$$$$$
login
transport input telnet ssh
scheduler max-task-time 5000
end
18 Replies 18
Dean,
I have same issues with Virgin net in the uk. Someone has suggested using 3-0-39 but you need a Smart Net to get it.
Jacob Samuel
Hi All
I am experiancing a same kind of scenario with my ADSL Link. In my case the Router is Cisco 2621.The CD LED is coming up for a second and goes down... again after few minits repeat the same.
This issue has started once after the Telco cut our link, normal telephone link, by mistake. After they connect the link back it showing this problem, there is no change on the device. Telco saying that there is no problem from their side and they showed the link working using a normal dsl modem.
yup it is workng with dsl modem but when i return to router atm interface the same issue, CD LED comes up and goes down freequently.
i have treid on the second adsl card, which is spare, on the same router, but the same result.
i am attching the router config and debugs
please check... i believe the problem again at the ISP side only they need to reset the Pots.... please correct if i am wrong on my statement and please help me out to fix the problem
regards
Jacob
Apparently the cut and repair of the line have caused a degradation in quality that the WIC-1ADSL is unable to handle.
You can only try upgrading IOS to see if newer ADSL FW can help. It may, or may not.
The current version should be indicated at the beginning of the training log that you have not included.
taherudin
Hello sir
I am new in cisco gear and i like to lurn cisco wher i am working cisco supplyers and we have many customers for cisco 877w ADSL modem will send me configration how to setup i dont have experiance in CLI command or if can send me screen short of SDM setup will be apreciatable
Taher
