ADSL- Loadbalancing
saed
Please your help. We need to install Cisco router with two lines ADSL ( WIC-1ADSL)- Loadbalancing - , what is your recomendation and which Cisco model we should use?
thanks
Giuseppe Larosa
Hello Saed,
to be able to use the two ADSL for load balancing you need a dedicated address block for the lan interface and for the site and the two ADSL have to come from the same provider.
if NAT is involved you can achieve redundancy but not real load balancing.
For the device a C2811 can be a good choice.
Hope to help
Giuseppe
paolo bevilacqua
The smaller router you can use is a 1841 with two HWIC-1ADSL.
I differ from Giuseppe's reply as with NAT the results are usually quite good.
