ADSL to GigEthernet
hassan_syed6
Guys i need someinput. I have got a Cisco 2621-XM router with IOS "flash:c2600-js-mz.123-19.bin". I am trying to have the connection from my ADSL Router to the Gig-E port Connection on the Cisco GSR.
Following is my CE config. Has anyone done any type of testing. Also one thing, i tried and couldn't do is " bundle enable" command. Not even sure if this IOS supports it. i tried to configure it in Gloabl Mode, under ATM0/1 also under PVC0/XX but it didn't take it. Any suggestionsss.....
bridge irb
interface ATM0/1
no ip address
ip mtu 1482
ip pim nbma-mode
ip pim sparse-mode
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
bridge-group 1
pvc 0/66
ubr 384
inarp 1
encapsulation aal5snap
max-reserved-bandwidth 100
interface BVI1
mac-address X.X.X
ip address X.X.X.X 255.255.255.252
no ip proxy-arp
bridge 1 protocol ieee
bridge 1 route ip
paolo bevilacqua
Hi, first of all, the ip commands that you have under atm0/1 will not have any effect because the interface doesn't have Ip enabled. If you really need these commands, put them under BVI1.
Second, why do you want bundle command?
I agree with you, that ip commands should be used under BVI, because that's what i am using for ADSL configuration, rather then ATM0/1.
I am not sure, someone has recommended to use bundle enable command, i am reading on cisco the implementation of this command.
Hassan...
