10-24-2011 07:10 AM - edited 03-04-2019 02:01 PM
I have a 2821 router with a ADSL wic installed that i am now trying to configure. I had the WIC card working & routing fine about 2 weeks ago when i was testing the configuration. But now i am trying to go live with the config i am unable to get the inside interface to ping anything on the internet?? I can ping from the router fine. I'm pretty sure i haven't changed the config since i last tested it, but could you guys take a quick look at the config & confirm i haven't missed anything??
Building configuration...
Current configuration : 23342 bytes
! Last configuration change at 23:00:57 AWT Mon Oct 24 2011 by admin
version 15.1
service password-encryption
hostname RT01
boot-start-marker
boot system flash:/c2800nm-advipservicesk9-mz.151-3.T1.bin
boot-end-marker
logging buffered 52000
enable secret 5 $1$SKrY$QnMFPnWoi8USRGJN6wCbJ/
aaa new-model
aaa authentication login default local
aaa authentication login nolog none
aaa authorization console
aaa authorization exec nolog none
aaa session-id common
clock timezone AWT 8 0
dot11 syslog
no ip source-route
ip cef
ip domain name xxxx.net
ip name-server 10.64.10.32
ip name-server 203.0.178.191
ip name-server 203.215.29.191
ip inspect name PIVoD ftp
ip inspect name PIVoD h323
ip inspect name PIVoD netshow
ip inspect name PIVoD udp
no ipv6 cef
license udi pid CISCO2821 sn FTX1037A1XU
username xxxx privilege 15 password xxxx
redundancy
ip tcp mss 1400
no ip ftp passive
bba-group pppoe global
interface Loopback1
ip address 203.X.X.X 255.255.255.255
interface GigabitEthernet0/0
description WAN link$ETH-WAN$
ip address 203.59.225.78 255.255.255.248
ip access-group External_In_2 in
ip nat outside
ip virtual-reassembly in
ip tcp adjust-mss 1412
shutdown
duplex auto
speed auto
crypto map PIVOD
interface Service-Engine0/0
no ip address
interface GigabitEthernet0/1
description DMZ
no ip address
duplex auto
speed auto
interface ATM0/2/0
no ip address
no atm ilmi-keepalive
interface ATM0/2/0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0/3/0
description $FW_INSIDE$$ETH-LAN$
ip address 10.x.x.x 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Dialer0
ip unnumbered Loopback1
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username XXXX password 7 XXXX
ip default-gateway 10.x.x.x (inside interface)
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 permanent
ip route 10.X.X.0 255.255.248.0 10.X.X.X
ip access-list extended DISABLED
ip access-list extended DISABLED2
ip access-list extended External_In_1
remark Protect us from the intertubes
remark
Kelvin
10-24-2011 09:19 AM
Where are the route-map used in the NAT config? Cant seem to find it.
10-24-2011 08:31 PM
Sorry i haven't been with the company long & the router is a bit of a mess, so i removed a lot of the config before posting, i must have removed the route maps as weel. I have now reposted most of the config
version 15.1
hostname PERO-RT01
boot-start-marker
boot-end-marker
aaa new-model
dot11 syslog
no ip source-route
ip cef
ip inspect name xxxx ftp
ip inspect name xxxx h323
ip inspect name xxxx netshow
ip inspect name xxxx udp
no ipv6 cef
voice-card 0
dspfarm
dsp services dspfarm
crypto pki trustpoint TP-self-signed-3329066066
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3329066066
revocation-check none
rsakeypair TP-self-signed-3329066066
crypto pki certificate chain TP-self-signed-3329066066
username xxxx privilege 15 password 7 xxxx
redundancy
ip tcp mss 1400
no ip ftp passive
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map match-any PPTP_VPN
match protocol gre
match protocol pptp
class-map match-all pi-test
match protocol pptp
class-map match-any Peer2Peer
match protocol gnutella
match protocol fasttrack
match protocol kazaa2
match protocol irc
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map match-any http-hacks
match protocol http url "*default.ida*"
match protocol http url "*cmd.exe*"
match protocol http url "*root.exe*"
match protocol http url "*readme.eml*"
match protocol http mime "*readme.exe*"
match protocol http mime "*readme.eml*"
match protocol http url "*/winnt/*"
match protocol http url "*cmd.exe"
match protocol http url "*root.exe"
match protocol http url "*/c+dir*"
class-map match-all IPSEC_VPN
match protocol ipsec
class-map match-all boo
class-map type inspect match-any ccp-dmz-protocols
match protocol http
match protocol https
class-map match-all nachi
match access-group 199
match packet length min 92 max 92
policy-map Handle_Incoming
class http-hacks
drop
class Peer2Peer
drop
class nachi
drop
class IPSEC_VPN
class PPTP_VPN
crypto isakmp policy 5
encr 3des
hash md5
authentication pre-share
group 2
lifetime 28800
crypto isakmp key PerOChaO67*$o#@ address 71.30.126.98
crypto isakmp key PerOAtlO67*$o#@ address 216.219.19.250 no-xauth
crypto isakmp identity dn
crypto isakmp keepalive 60
crypto ipsec transform-set xxxx_Default esp-3des esp-md5-hmac
crypto ipsec profile secure
set identity hqvpn
crypto call admission limit ike in-negotiation-sa 10
crypto map xxxx 10 ipsec-isakmp
set peer 216.219.19.250
set transform-set xxxx_Default
set pfs group2
match address PerO_to_AtlO
crypto map xxxx 20 ipsec-isakmp
set peer 71.30.126.98
set pfs group2
match address PerO_to_ChaO
interface Loopback1
ip address 203.59.48.236 255.255.255.255
ip nat outside
shutdown
duplex auto
speed auto
crypto map xxxx
no ip address
description DMZ
no ip address
duplex auto
speed auto
interface ATM0/2/0
no ip address
pvc 8/35
ip address 10.64.8.253 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Dialer0
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username xxxx password 7 xxx
ip default-gateway 10.64.8.253
ip http server
ip nat inside source static tcp 10.64.10.38 443 203.59.225.76 443 extendable
ip nat inside source static tcp 10.64.9.240 443 203.59.225.77 443 extendable
ip route 10.64.8.0 255.255.248.0 10.64.8.254
remark
remark Anti spoofing and other requiring a deny
deny ip 10.64.8.0 0.0.7.255 any log-input
remark
remark Allow TCP replys
permit tcp any any established
remark
remark Allow DMZ servers to get to required resources
remark * Database services (SQL, PostGres, MySQL)
permit tcp 203.59.225.72 0.0.0.7 host 10.64.10.37 eq 1433
permit tcp 203.59.225.72 0.0.0.7 host 10.64.10.37 eq 5432
permit tcp 203.59.225.72 0.0.0.7 host 10.64.10.37 eq 3306
remark * SMTP
permit tcp 203.59.225.72 0.0.0.7 host 10.64.10.39 eq smtp
remark * Ping requests to servers
permit icmp 203.59.225.72 0.0.0.7 10.64.10.0 0.0.0.255
remark * Active Directory to DCs (NTP, -LDAP-, sLDAP, -Glob Catalog-, sGlob Cat, Kerberos, sKerberos)
permit udp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq ntp
permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 389
permit udp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 389
permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 636
permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 3268
permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 3269
permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 88
permit udp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 88
permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 464
permit udp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 464
remark
remark Temporary rules to allow Group Policy from DCs (http://support.microsoft.com/kb/832017)
remark Rem out once policies applied.
remark permit udp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 gt 49152
remark permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 gt 1024
remark permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 445
remark permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 135
remark permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 137
remark permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 138
remark permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 139
remark permit tcp 203.59.225.72 0.0.0.7 10.64.10.32 0.0.0.15 eq 593
remark Allow pings to DMZ Gateway
permit icmp any host 203.59.225.78
remark
remark Allow HTTPS to ausdc-www3 (sharepoint)
remark - Note, uses NAT fwd
permit tcp any host 203.59.225.76 eq 443
remark
remark Allow HTTPS to gw (CITRIX)
permit tcp any host 203.59.225.77 eq 443
remark
remark Allow DNS replies and queries
permit udp any eq domain any gt 1023
remark
remark Allow replies to outbound VPNs
permit udp any eq isakmp any gt 1023
permit udp any eq non500-isakmp any gt 1023
permit udp any eq 10000 any gt 1023
remark
remark Allow all UDP in - helping Skype, LogMeIn etc
permit udp any any
remark
remark Default ICMP
permit icmp any any parameter-problem
permit icmp any any source-quench
permit icmp any any echo-reply
permit icmp any any time-exceeded
permit icmp any any unreachable
remark
remark Now we deny stuff and log some of it
deny icmp any any echo tos normal log-input
deny icmp any any log-input
deny tcp any any eq smtp log-input
deny tcp any any eq 1025 log-input
deny udp any any eq 1026 log-input
deny udp any any eq 1027 log-input
deny tcp any any eq 2745 log-input
deny udp any any eq 2745 log-input
deny tcp any any eq 445 log-input
deny tcp any any eq 1433 log-input
deny udp any any eq 1434 log-input
deny tcp any any eq 135 log-input
deny udp any any eq netbios-ns log-input
deny udp any any eq 3127 log-input
deny tcp any any eq 3127 log-input
deny tcp any any eq 139 log-input
deny tcp any any eq ident log-input
deny tcp any any eq 6129 log-input
remark
remark Unrem these lines for trouble-shooting
remark The denies are implicit anyway but these lines cause them to log
remark View logs live on OLIVE via Kiwi Syslog Daemon viewer
deny tcp any any log-input
deny gre any any log-input
remark
ip access-list extended External_In_2
remark
remark
remark
remark Allow Atlanta Office VPN through
permit esp host 216.219.19.250 host 203.59.225.78
permit ahp host 216.219.19.250 host 203.59.225.78
permit udp host 216.219.19.250 host 203.59.225.78 eq isakmp
permit icmp host 216.219.19.250 any
permit ip 192.168.148.0 0.0.3.255 10.64.8.0 0.0.7.255
remark
remark Allow Charlotte Office VPN through
permit esp host 71.30.126.98 host 203.59.225.78
permit ahp host 71.30.126.98 host 203.59.225.78
permit udp host 71.30.126.98 host 203.59.225.78 eq isakmp
permit icmp host 71.30.126.98 any
permit ip 192.168.144.0 0.0.3.255 10.64.8.0 0.0.7.255
remark
remark * SMTP
remark
remark
remark
remark
remark Allow replies to PPTP (Windows) VPNs
permit gre any any
remark
remark
remark
permit udp any any
remark
remark Default ICMP
remark
remark deny tcp any any log-input
remark
ip access-list extended External_NAT_1
remark Rules for NATing outbound
remark CCP_ACL Category=18
deny tcp host 10.64.9.240 eq 443 any
remark Don't NAT internal traffic destined for VPNs - might not be needed
deny ip 10.64.8.0 0.0.7.255 192.168.148.0 0.0.3.255
deny ip 10.64.8.0 0.0.7.255 192.168.144.0 0.0.3.255
remark Don't NAT internal traffic destined for DMZ
deny ip 10.64.8.0 0.0.7.255 203.59.225.72 0.0.0.7
remark NAT all traffic from LAN
permit ip 10.64.8.0 0.0.7.255 any
ip access-list extended Internal_Out_1
remark Protect internet from us!
remark
remark Allow mail out from mail server
permit tcp host 10.64.10.39 any eq smtp
remark
remark Deny accidental SMTP
remark
remark Allow everything else
permit ip any any
ip access-list extended Internal_Out_2
remark
remark
remark Allow mail to iiNet's relay (David P)
permit tcp any host 203.0.178.192 eq smtp
remark
remark
permit ip any any
ip access-list extended PerO_to_AtlO
permit ip 10.64.8.0 0.0.7.255 192.168.148.0 0.0.3.255
ip access-list extended PerO_to_ChaO
permit ip 10.64.8.0 0.0.7.255 192.168.144.0 0.0.3.255
ip access-list extended SDM_AH
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended Temp
logging esm config
logging 10.64.10.32
dialer-list 1 protocol ip permit
route-map SDM_RMAP_1 permit 1
match ip address External_NAT_1
route-map SDM_RMAP_2 permit 1
snmp-server community xxxxRO RO 50
snmp-server community xxxxAccess RW 10
snmp-server community xxxxmon RO
tftp-server flash:Desktops/320x212x12/logo123.png
tftp-server flash:Desktops/320x212x12/log123tn.png
tftp-server flash:Desktops/320x212x12/logo123tn.png
tftp-server flash:/Desktops/320x212x12/logo123tn.png
tftp-server flash:/Desktops/320x212x12/logo123.png
tftp-server flash:/Desktops/320x212x12/List.xml
tftp-server flash:/Desktops/320x212x12/xxxxlogo.png
tftp-server flash:/Desktops/320x212x12/xxxxlogotn.png
tftp-server flash:/SCCP70.8-2-2SR3S.loads
tftp-server flash:/apps70.8-2-2ES4.sbn
tftp-server flash:/cnu70.8-2-2ES4.sbn
tftp-server flash:/cvm70sccp.8-2-2ES4.sbn
tftp-server flash:/dsp70.8-2-2ES4.sbn
tftp-server flash:/jar70sccp.8-2-2ES4.sbn
tftp-server flash:/term70.default.loads
tftp-server flash:/term71.default.loads
tftp-server flash:/P
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
tftp-server flash:RingList.xml
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:/P003-07-3-00.bin
tftp-server flash:/P003-07-3-00.sbn
tftp-server flash:P003-07-3-00.sbn
tftp-server flash:Desktops/320x212x12/xxxxlogo.png
tftp-server flash:Desktops/320x212x12/xxxxlogotn.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:CTU.raw
tftp-server flash:CTU24.raw
tftp-server flash:SCCP70.8-2-2SR3S.loads
tftp-server flash:apps70.8-2-2ES4.sbn
tftp-server flash:cnu70.8-2-2ES4.sbn
tftp-server flash:cvm70sccp.8-2-2ES4.sbn
tftp-server flash:dsp70.8-2-2ES4.sbn
tftp-server flash:jar70sccp.8-2-2ES4.sbn
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:/OS79XX.TXT
tftp-server flash:P0S3-07-3-00.loads
tftp-server flash:P0S3-07-3-00.sb2
tftp-server flash:P003-07-3-00.bin
tftp-server flash:P00308000500.bin
tftp-server flash:P00308000500.loads
tftp-server flash:P00308000500.sbn
tftp-server flash:P00308000500.sb2
tftp-server flash:OS79XX.txt
tftp-server flash:/Desktops/320x212x12/xxxxLogoNEWDark.png
tftp-server flash:/Desktops/320x212x12/xxxxLogoNEWDark_thumbnail.png
tftp-server flash:Desktops/320x212x12/xxxxLogoNEWDark.png
tftp-server flash:Desktops/320x212x12/xxxxLogoNEWDark_thumbnail.png
tftp-server flash:S00105000300.sbn
tftp-server flash:/S00105000300.sbn
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
mgcp profile default
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
maximum sessions 12
associate application SCCP
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 32
sdspfarm tag 1 mtp00192f2a5319
video
no auto-reg-ephone
max-ephones 52
max-dn 192
load 7914 S00105000300
load 7920 cmterm_7920.4.0-02-01
load 7960-7940 P00308000500
load 7970 SCCP70.8-2-2SR3S
max-conferences 8 gain -6
call-forward pattern .T
hunt-group logout HLog
moh music-on-hold.au
dn-webedit
transfer-system full-consult
transfer-pattern .T
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
fac standard
create cnf-files version-stamp 7960 Nov 03 2009 03:11:45
ephone-template 1
softkeys hold Newcall Resume
softkeys idle Newcall Redial Dnd Cfwdall HLog
softkeys seized Callback Cfwdall Endcall HLog Redial
softkeys alerting Callback Endcall
softkeys connected Trnsfer Hold Confrn Endcall
ephone-template 2
ephone-template 3
type 7970
line con 0
privilege level 15
logging synchronous
line aux 0
line 194
access-class 19 in
login authentication nolog
no activation-character
no exec
transport preferred none
transport input all
transport output all
line vty 0 4
exec-timeout 0 0
privilege level 15
transport input ssh
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0
ntp server 10.64.10.32
end
