Bookmark
Subscribe
1494
show interface vlan
estelamathew
Level 2
Level 2
Dears,
I see packets drops in the network,when i try to ping the remote branches which are connected through MPLS cloud, but it happens every day or two with no specific time,How  i shld trace the problem is in my network or at MPLS cloud,????????? And which location packets are dropping how i will come to know,?????? trace route is blocked in MPLS cloud.
Below is the sh interface of vlan in which my desktop is connected and i m trying to ping the remote branch router.
CORE#sh int vlan 100
Vlan100 is up, line protocol is up
  Hardware is EtherSVI, address is X>X>>X
  Description: ****  ****
  Internet address is 10.X.X.1/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/321/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 121000 bits/sec, 68 packets/sec
  5 minute output rate 417000 bits/sec, 71 packets/sec
  L2 Switched: ucast: 47480442 pkt, 30928486216 bytes - mcast: 17629127 pkt, 1847524067 bytes
  L3 in Switched: ucast: 164837681 pkt, 51589735598 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 217394950 pkt, 207167898709 bytes mcast: 0 pkt, 0 bytes
     176505264 packets input, 52509410688 bytes, 0 no buffer
     Received 10449316 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 20 throttles
     224697055 packets output, 207653461208 bytes, 0 underruns
     0 output errors, 0 interface resets
jimmysands73_2
Level 5
Level 5
Point A The router on the edge of your site--------MPLS cloud--------Point B The router on the other side of the MPLS cloud
PIng from A to B, if still a problem, to me its a service provider issue.
Dear,
I dont have access to MPLS router in my premises, But is try to ping from Desktop to the internal interface of MPLS router which is connected to core switch then also i can get the result.  I'm correct???????
Apart from this what toubleshooting hints can you give me for the Core which is connected to MPLS router in my premises.
I do not see that as a good test.  If are pinging on your internall network to the MPLS routers int...when does it enter the clou?.  If your pinging from your desktop, you throw in patch cables, physical networking port, access switches, that all could have an influence on your ping time.    If you think your SP is the problem, have them check the line.  If they did and say nothing is wrong, then you will need greater access to your network to discover the culprit.
