ADSL2+ Annex M support
shanemoss
Hi Folks,
I have a 887G router with ADSL connectivity to my service provider.  I can sync at;
DSL Mode:        ITU G.992.1 (G.DMT) Annex A
The service provider offers higher speed connectivity vioa ADSL2+ but my router must support Annex M.  As far as I'm aware from the Cisco docs it should support but it will not sync up.  I think that I should see Annex M as an option uner the line config but I don't.
Router(config-if)#dsl operating-mode ?
  adsl2     ITU G.992.3 Annex A and L
  adsl2+    ITU G.992.5 Annex A
  ansi-dmt  ANSI T1.413
  auto      auto detect mode
  itu-dmt   ITU G.992.1 Annex A
  <cr>
It's also not an option as some documents describe as an extension to the command;
Router(config-if)#dsl operating-mode adsl2+ ?
  <cr>
I think that my IOS may not support it, I am running version;
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(3)T1, RELEASE SOFTWARE (fc2)
Does anyone know what IOS that I need to support Annex M?
Thanks in advance,
Shane.
As mentioned above:
Only specific 880 series models supports Annex M.
In the document you linked, look for these on Table 19.
Please remember to rate useful posts clicking on the stars below.
5 Replies 5
riroe
Level 3
Level 3
Hi Shane--This Community Forum area is for Cisco Small Business Products. The Cisco 887G Router is not a
Cisco Small Business Router. You might want to post this at the Support Community that supports that type of router.
THANKS
Rick Roe
Cisco Small Business Support Center
paolo bevilacqua
It's not IOS matter, you need a specific -M model to use Annex M, that is CISCO887VA-M-K9
Try asking your ISP to downgrade you to non-M.
Next time you can ask in WAN Routing and switch as you have a true IOS, Enterprise product, not Small Business one.
Thanks for your reply - I was afraid that it might be a hardware issue, however according to the DSL specifications on the following page, the 887 is shown to support Annex M,
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542_ps380_Products_Data_Sheet.html
This is why I thought my problem was IOS related.
Shane.
As mentioned above:
Regarding the new 887-VA models with the Broadcom multimode chipsets,  Annex M support will apparently be added to the Annex A models in a future IOS  release. This is, of course, no help to the OP if he has an older ST Micro based model.
http://www.cisco.com/en/US/customer/prod/collateral/routers/ps380/qa_c67-612339.html
Q. Is Annex M supported on the Cisco 887VA Annex A platform?
A. At product FCS, Annex M is not supported on the Cisco 887VA Annex A   platform. Annex M support will be enabled on the Cisco 887VA Annex A   platform with a later Cisco IOS® Software release.
