Adv new subnet to ISP and Inbound soft reconfiguration
mahesh18
Level 6
Level 6
Hi Everyone,
We have BGP nei with one of ISP and we are not advertising our network to them.
show ip bgp neighbors 206.x.x.253 received-routes
% Inbound soft reconfiguration not enabled on 206.x.x253
I checked route refresh is configured by default.
If i advertise our network to them and run the above command again then I should see received routes from the ISP right?
Mahesh
10 Replies 10
not sure what you are asking. Seeing the routes with the command you mentioned is not related to sending your own network(s) to the ISP. You need soft reconfiguration configured in order to use that command.
sh ip bgp neighbors x.x.x.x routes
does work with the soft reconfiguration inbound configured.
What I wanna achieve is advertise our network to ISP and then learn the routes from the ISP.
To make this work do i need to config soft reconfig for that ISP network?
nazimkha
You need to run this command on your router to check advertised routes
show ip bgp neighbors 206.x.x.253 advertised-routes
Hello
Enabling soft reconfiguration can have a detrimental effect your rrtr cpu/memory processing if it’s advertising/receiving lots of prefixes .
Nowadays you should not have to enable any soft reconfiguration as bgp supports route refresh which is a lot more efficient to update the adj ribs via a soft reset of each neighbor -
As such this RR capability does not need to store any additional bgp table to accommodate each of its bgp neighbours unprocessed prefixes .
if you do -
sh ip bgp neighbor | in Cap
This will tell you if your router and it’s bgp neighbor supports RR
Lastly to view advertised and receivied prefixes:
sh ip bgp neighbours xxxx routes
sh is bgp neighbours xxxxx advertised routes
To do a no disruptive RR soft reset of a neighbor  use-
clear ip bgp neighbor xxx soft in/out
 Or
clear ip  bgp * soft  - for all peers in/out
Kind Regards
Paul
I agree with those above.  If you want to see who you are peering with run sh ip bgp sum.  This will tell you how many prefixes your are receiving from a given peer.  Run sh ip bgp nei x.x.x.x adv to see which routes you are advertising and sh ip bgp nei x.x.x.x route to see which routes you are receiving.
thanks for very usefull info
to check if RR is configured on nei router i run this command
show ip bgp neighbor 206.x.x.253 | inc Cap
Four-octets ASN Capability: advertised and received
Graceful Restart Capability: received
Enhanced Refresh Capability: advertised
Multisession Capability:
how can i tell from this if local and nei router are configured with RR?
Best Regards
Mahesh
Best Regards
Mahesh
Hello
it looks like this neighbor is capable of outbound rr updates
Just to confirm post the following:
show ip bgp neighbor 206.x.x.253 | be  Neighbor cap
or
show ip bgp neighbor 206.x.x.253 | be  Route
Kind Regards
Paul
I run that command it shows no output.
Best Regards
Mahesh
