Advertising a subnet by BGP in a backup router
I have two routers working as main and backup via HSRP. Both of them are advertising the subnet 172.10.10.0/24, the question is I need that the packets with destiny 172.10.10.64/26 subnet, go through the backup router. I applied a route-map with a prefix-list in backup router that include the 172.10.10.64/26 subnet with a better metric. However the packets which are sent to that subnet go through main router. This is the configuration:
- Backup Router (standby status)
router bgp 1000
 no synchronization
 bgp log-neighbor-changes
 network 172.10.10.0
 redistribute connected
 redistribute static
 neighbor iBGP peer-group
 neighbor iBGP remote-as 1000
 neighbor iBGP route-map iBGP-OUT out
 neighbor x.x.x.x remote-as 500
 neighbor x.x.x.x description BGP
 neighbor x.x.x.x timers 10 30
 neighbor x.x.x.x next-hop-self
 neighbor x.x.x.x send-community
 neighbor x.x.x.x route-map INPUT_NET in
 neighbor x.x.x.x route-map USER_NET out
 neighbor y.y.y.y peer-group iBGP
 neighbor z.z.z.z peer-group iBGP
 no auto-summary
ip route 172.10.10.0 255.255.255.0 192.168.1.20
ip route 172.10.10.64 255.255.255.192 192.168.1.20
ip prefix-list USER_NET1 seq 1 permit 172.10.10.0 /24
ip prefix-list USER_NET2 seq 1 permit 172.10.10.64/26
route-map USER_NET permit 10
 match ip address prefix-list USER_NET1
 set metric 105
route-map USER_NET permit 20
 match ip address prefix-list USER_NET2
 set metric 90
route-map iBGP-OUT permit 10
 set metric 300
 set local-preference 100
- Main Router (active status)
router bgp 1000
 no synchronization
 network 172.10.10.0
 redistribute static
 neighbor a.a.a.a remote-as 500
 neighbor a.a.a.a description Sesion BGP PRINCIPAL
 neighbor a.a.a.a timers 10 30
 neighbor a.a.a.a next-hop-self
 neighbor a.a.a.a send-community
 neighbor a.a.a.a route-map INPUT_NET in
 neighbor a.a.a.a route-map USER_NET out
 no auto-summary
 set metric 100
 set metric 300
 set local-preference 50
What can i do?
Note: The objetive is all traffic with source or destination 172.10.10.64/26 subnet go through backup router. If backup router fails, the traffic tothat subnet must go through the main router.
Thank you and sorry for my english
Robert Falconer
Is this an internal or external BGP?
Is 172.10.10.0/24 actually split into multiple subnets or is there just a single /24?
What does your HSRP configuration look like?
What does the configuration look like on the other side of the BGP session?
Internal BGP
It's a single /24, but the users have a group of servers with ip addresses within 172.10.10.64/26.
Backup Router:
interface Vlanxx
 description VLAN port LAN
 ip address xxxxxxxxxxx
 no ip redirects
 no ip proxy-arp
 load-interval 30
 standby 1 ip yyyyyyyyy
 standby 1 preempt
 standby 1 track GigabitEthernet0/1
interface GigabitEthernet0/0.102
 description User LAN
 encapsulation dot1Q 102
 ip access-group 101 out
 no ip redirects
 no ip proxy-arp
 no cdp enable
 standby 3 ip xxxxxxxxxxx
 standby 3 preempt
 standby 3 track GigabitEthernet0/1
Main router:
interface Vlanxx
 no ip redirects
 no ip proxy-arp
 load-interval 30
 standby 1 preempt
 standby 1 priority 105
 no ip redirects
 no ip proxy-arp
 no cdp enable
 standby 3 preempt
standby 3 priority 105
In the other side. the preferred route for all nets is the main router. The 172.10.10.64/26 looks like summarized in 172.10.10.0/24
