Advice on Router Purchase Please.
backpedal
HI, I'm new to CISCO Routers and I'm looking for advice on which unit I should consider buying. My requirements are :
1. There should be an Internet / WAN UK ADSL connection.
2. It needs to be able to support 4 public IP addresses that can be routed to different servers. i.e
81.86.100.1 - 192.168.1.1
81.86.100.2 - 192.168.1.5 etc.
3. Support to create a DMZ.
Advice on which unit I should consider would be appreciated.
spremkumar
Level 9
Level 9
Hope you can make use of Cisco 877 series router which supports all your requirements...
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html
regds
