After configuring routing between VLAN's, reachability outcomes varies
guhanece
With reference to above Topology involving ACCESS VLAN's:
Generally, it is well defined and understood that : Routing is required to switch & reach the traffic between 2 different VLAN's.
So, defined the static route / default route ( In this example , I am using default route)
ip route 0.0.0.0 0.0.0.0 vlan 200  - on Switch-FIRST
ip route 0.0.0.0 0.0.0.0 vlan 100 - on Switch-SECOND
ip route 0.0.0.0 0.0.0.0 192.168.1.10 -  on Switch-SECOND
Whereas with above referred topology: From "Switch-SECOND" - Able to successfully reach 172.10.1.1 ( L3 interface connected on Switch-FIRST).
But, Unable to reach 192.168.2.10 which is assigned with VLAN200.
Kindly Justify - even after adding static route taking Vlan100 and NH-IP(192.168.1.10) - Unable to get PING 192.168.2.10 SUCCESSFUL from "Switch-SECOND"
With Catalyst Devices Solution is achievable:
Identified that through creating "do1Q encapsulation " on Switch-FIRST and Keeping the Switch-FIRST and Switch-SECOND  in same TRUNK mode:
Reach-ability between VLAN100 from Switch-SECOND to VLAN200 of Switch-FIRST is achievable through assigning "encapsulation do1q 100" on  Fa0/2 of Switch-FIRST, and "switchport mode trunk on link between Switch-FIRST and Switch-SECOND"
Insightful findings:
In-spite of understanding that " Routing is enough to provide between VLAN's" -> It should be understood that " Routing can be provided between VLAN's considering Required VLAN's are allowed as in TRUNK mode  ( Or SVI VLAN's in TRUNK mode)  to allow the traffic on connected "SVI interface IP " ( which is a  destined IP address ).
Kindly correct - does my Insightful findings is correct with understanding or different.
Attached the Switch-FIRST and Switch-SECOND , and intermediate  Switch0 configurations:
Switch-FIRST#show ip interface brief | inc up
FastEthernet0/1 unassigned YES unset up up
FastEthernet0/2 unassigned YES unset up up
FastEthernet0/3 172.10.1.1 YES manual up up
Vlan100 192.168.1.10 YES manual up up
Vlan200 192.168.2.10 YES manual up up
Switch-FIRST#
interface Vlan100
mac-address 0040.0b66.d101
ip address 192.168.1.10 255.255.255.0
interface Vlan200
mac-address 0040.0b66.d102
ip address 192.168.2.10 255.255.255.0
ip classless
ip route 192.168.2.0 255.255.255.0 Vlan200
ip flow-export version 9
Switch-SECOND#show ip interface brief | inc up
Vlan100 192.168.1.20 YES manual up up
Vlan200 192.168.2.20 YES manual up up
Switch-SECOND#
interface FastEthernet0/1
switchport access vlan 100
switchport mode access
interface FastEthernet0/2
switchport access vlan 200
Switch0:
hostname Switch0
spanning-tree mode pvst
fracjackmac
Hello @guhanece,
A few observations:
First, the switchport mode access configuration command is typically used on interfaces that connect exclusively to end devices.
Second, when you connect network infrastructure devices together using Layer 2 interfaces, you would typically use trunk interfaces (switchport trunk encapsulation dot1q  +  switchport mode trunk ) if you plan to distribute more than one VLAN across multiple switches.
For example, on Switch-SECOND, you might want to change the config on Fa0/1:
config t
interface fa0/1
no switchport access vlan 100
end
Switch0 would need similar config changes on both interfaces Fa0/1 and Fa0/2 so that traffic for both VLAN 100 and VLAN 200 can move back and forth between Switch-FIRST and Switch-SECOND.
Interface Fa0/2 on Switch-FIRST would also need to be converted from an access port to a trunk port.
Third, the reason you are able to ping 172.10.1.2 from Switch-SECOND:
1) ip route 0.0.0.0 0.0.0.0 vlan 100 tells the management host on Switch-SECOND that EVERYTHING that is not directly connected
can be reached by sending traffic out interface Fa0/1, which is using vlan 100 and an IP address of 192.168.1.20.
2) When 172.10.1.2 is sent a ping request from Switch-SECOND, the management host, using a source address of 192.168.1.20,
uses the default route to send the traffic out interface Fa0/1.
3) When the traffic gets to Switch0, switch 0 simply takes the incoming traffic for vlan 100 and floods it out ALL interfaces
that are part of vlan 100 except the interface that the traffic came in on.
NOTE: The switch does not "own" the destination IP address, so the traffic is forwarded using the "U" (Unknown Unicast) in the
Layer 2 BUM rules. This gets the traffic to Switch-FIRST without the need for any routes on Switch0.
4) Switch-FIRST sees the incoming destination address, recognizes that it has a directly connected host on Fa0/3 with that
address, and sends the traffic out Fa0/3 to PC2.
NOTE: Since no vlan is mentioned for interface Fa0/3 and there is an IP address assigned, the route table should have a
connected route
that allows the traffic to be forwarded.
5) PC2 uses its default gateway (172.10.1.1) to reply to the ping request from Switch-SECOND.
NOTE: Since the destination address for the ping reply is in a known subnet (vlan 100), Switch-FIRST will send an ARP request
out the Fa0/2 interface and receive an ARP reply from Switch-SECOND, so no Layer 3 routing is required to get the
traffic back to Switch-SECOND.
Fourth, if the ping was initiated from PC1, there would be no reply because the source address of 192.168.2.40 is part of vlan 200.  Traffic leaving PC2, destined for a vlan 200 subnet, would be flooded out all vlan 200 interfaces on Switch-FIRST, but since there is no interface to Switch0 that allows vlan 200 traffic, there is no path back to PC1.
Recall that the default route is ONLY used when there is no other route available.
Happy networking!!!
@@ittybittypacket
fracjackmac
Hello @guhanece,
A few observations:
config t
interface fa0/1
end
connected route
Happy networking!!!
@@ittybittypacket
Joseph W. Doherty
BTW, generally it's poor practice to not use a next hop IP for any static route, especially a default route.
The latter, when going to the Internet, often creates a ARP table so large, it will memory exhaust a router.
