11-05-2007 03:32 AM - edited 03-03-2019 07:24 PM
I upgrade the IOS on my cisco 837 router to use the IDS function and after completing machines from the inside can not go to the internet. from the router I can ping out to the internet. can anyone see anything in this config that would be preventing it working?
thanks
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec show-timezone
service timestamps log datetime msec show-timezone
service password-encryption
hostname router
boot-start-marker
boot system flash c837-k9o3sy6-mz.124-17.bin
boot-end-marker
logging buffered 16000 debugging
enable secret xxxxxxxxxx
no aaa new-model
clock timezone GMT 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 1:00
ip source-route
no ip gratuitous-arps
ip cef
no ip domain lookup
ip name-server 159.134.248.17
no ip bootp server
ip inspect max-incomplete low 10
ip inspect max-incomplete high 20
ip inspect one-minute low 10
ip inspect one-minute high 20
ip inspect udp idle-time 15
ip inspect tcp idle-time 1800
ip inspect tcp finwait-time 1
ip inspect tcp synwait-time 10
ip inspect name MYFW udp alert on audit-trail on
ip inspect name MYFW tcp alert on audit-trail on
vpdn enable
username user password xxxxxxxxx
ip ssh time-out 60
ip ssh authentication-retries 2
interface Ethernet0
ip address x.x.x.x(public address) 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1452
no cdp enable
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
pvc 8/35
encapsulation aal5snap
pppoe-client dial-pool-number 1 dial-on-demand
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer0
no ip address
no cdp enable
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer idle-timeout 14400
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname user
ppp chap password password
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip access-list extended INTERNET-IN
deny ip any any log
access-list 100 permit ip any any
access-list 100 permit tcp host 1.2.3.4 any log
access-list 100 deny ip any any log
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
exec-timeout 0 0
login local
no modem enable
transport preferred none
transport output none
stopbits 1
line aux 0
login local
no exec
line vty 0 4
access-class TELNET in
exec-timeout 0 0
login local
length 0
transport input telnet
scheduler max-task-time 5000
end
11-05-2007 03:43 AM
hi
can you do a trace and find out where the packets are getting dropped ?
can you also do a extended ping with source ip address as your ethernet ip ?
do try tracing from router as well as from pc.
from router with extended trace with source ip address as your ethernet ip.
regds
11-05-2007 03:49 AM
the packets are being dropped on the ethernet interface on the router which connects to the inside hosts.
I can not ping the IP on that interface.
everything was working fine until I performed the upgrade.
