AIM-ATM not recognize
yavuz.ozdemir
I'm trying to configure a router in ATM IMA but I have a problem to configure the mode atm ima under the controller.
I installed the ATM IMA module on the mother board but I do a sh diag :
WIC Slot 0:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : B0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC11521VCT
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 31 35 32 31 56 43 54 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
and my version is Version 12.4(3h)
and sh ver 2 FastEthernet interfaces
2 Channelized (E1 or T1)/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Can you advice me, please.
yavuz.ozdemir
I upgraded from 12.4(3H) to 12.4(11)T4 thinking that it might take care of the problem but now I see in the sh diag CLI
my ATM IMA module but when I do a sh ver I don't see the module AIM. And still I can't configure atm ima on the controller.
card type e1 0 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
yourname(config)#controller E1 0/0/0
yourname(config-controller)#mode ?
cas Configure CAS (Channel Associated Signal) mode
ccs Configure CCS (Common Channel Signal) mode
Which exact IOS are you running?
You might need "SP services" or "advanced IP services" image for ATM IMA.
