E1 Connection
b.fawaz.emr
Dears
I have Site to Site Serial throught E1 connection I created OSPF as we design our network, Any way I have many site all of them working fine, but in the last I add one site througth E1 when I continues ping is giving many Request Time Out. Are this problem with Tranismion Team they have to check The Link or configuration. Because I am to telenet to remote site.
16 Replies 16
paolo bevilacqua
First check "show controllers e1". Any error is indicative of a problem on the circuit.
This is the output please advice:
E1 0/2/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20050620, FPGA: 16, spm_count = 0
Framing is UNFRAMED, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (345 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 10 15 minute intervals):
179 Line Code Violations, 0 Path Code Violations,
2 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 40 Unavail Secs
E1 0/2/1 is up.
No alarms detected.
345 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
345 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
8433511 Line Code Violations, 0 Path Code Violations,
7864 Slip Secs, 0 Fr Loss Secs, 9 Line Err Secs, 1 Degraded Mins,
7864 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 2202 Unavail Sec
s
Is this an ISR router ? If so do you have the required commands ?
network-clock-participate
and
network-clock-select E1 0/2/1 1
Still request time out comming
What is mean
Means there is clock slippage between circuit clock and router clock. Have you configure the commands ? Please send output of "show network-clocks".
What is on the other side ? You can try turning "clock source internal" on one side of the link only.
EDG-RO1-WMX-JUB#show network-clocks
Network Clock Configuration
Priority Clock Source Clock State Clock Type
1 E1 0/2/1 GOOD E1
11 Backplane GOOD PLL
Current Primary Clock Source
1 E1 0/2/1 GOOD E1
REM-R01-ALR-DCK#show network-clocks
Priority 1 clock source: not configured
Priority 2 clock source: not configured
Priority 3 clock source: not configured
Priority 4 clock source: not configured
Priority 5 clock source: Local oscillator
Current clock source:Local oscillator, priority:5
EDG-RO1-WMX-JUB#
controller E1 0/2/1
channel-group 0 unframed
REM-R01-ALR-DCK#
controller SONET 2/0
framing sdh
au-4 1 tug-3 1
tug-2 1 e1 1 unframed
tug-2 1 e1 2 unframed
tug-2 1 e1 3 unframed
tug-2 2 e1 1 unframed
tug-2 2 e1 2 unframed
tug-2 2 e1 3 unframed
tug-2 3 e1 1 unframed
tug-2 3 e1 2 unframed
tug-2 3 e1 3 unframed
tug-2 4 e1 2 unframed
au-4 1 tug-3 2
tug-2 7 e1 1 unframed
description "STM-1 Chanalized E1 to remote sites"
The problem in EDG-RO1-WMX-JUB#
hi, the only thing you can try is "clock source internal" on edg router, if not that, it's a problem with the circuit and you need to have it fixed.
HI Paolo
After I enter the following command clock source internal. The ping is fine for 15 continues ping but after that one request time out and come back 15 or 20 continues ping and the one request time out>>>>> please advice….
You have to check "show controllers E1".
As long the slip and error counter is present, something is wrong with the circuit.
The error before it was 9 error
but now the errors 0
Do clear counter and check there are no more errors.
Also check on the other side, under serial interface, that there are no errors. Probably there are.
from another site is SONET Configured please advice.
Still you have a logical serial interface for this link on the sonet router, so check for errors on it.
