AIR-AP1242AG-E-K9 versus AIR-AP1242AG-A-K9
vesnajovanovic
Differences between these two products??
desai.jaideep
Level 5
Level 5
There is the difference for a specific country compliance. "A" is for Americas and "E" is for Europe.
The major difference is bandwidth spacing of 2.4GHz band. One is having 11 channels and one 13.
JD
Thank you for the answer. As my customer's gotten the "A" instead of "E" by mistake, I assume he can use that "A" one and existing 11 channels.
Sure he can.
Pls rate if I had helped.
JD
