aironet 1140 access point / 1941 router question
steve
I currently have:
- 1941 (not wireless) router
- 1140 Access Point
It looks like I got the controller-based AP instead of the standalone.  My question is, does the 1941 (not 1941W) have a wireless controller?  If not, is there a controller module that I can add to my router?  Or should I return the AP I have for the standalone version (or the 1941 for the 1941W)?
Thanks in advance for any advice / assistance.
Collin Clark
There is not a controller that can go into the 1941. The controllers are pretty expensive so you probably do not want to go that route anyway. Before sending the AP back, open a TAC case and see if you can convert it to a standalone. Some AP's support this, but I'm not sure about the 1140 series.
Hope it helps.
Collin Clark
Hope it helps.
Collin,
Thanks very much for the quick reply.  It looks like you can use a standalone as a lightweight, but not vice versa... Guess I'll have to replace it.
Upon further review, it looks like you can switch from lightweight to autonomous:
https://supportforums.cisco.com/docs/DOC-12887
