%ALIGN-3-TRACE: -Traceback=
smartboy2255
HI,
  I am Getting following error in Cisco 3700 Router with IOS 12.3 (26).We dont have any option to upgrade IOS since this is the only available IOS in the particular feature Set.What could be cause of this particular error...
%ALIGN-3-TRACE: -Traceback= 609BEFC4 609BF9A4 609C01C0 60992D64 60993310 00000000 000
00000 00000000
%ALIGN-3-CORRECT: Alignment correction made at 0x609BEFE4 writing 0x4722BDAB
kahamid
Can you please attach "show version" from device here so I can decode tracebacks.
Kashif
HI,
PLs find the show version of Router
sh ver
IOS (tm) 3700 Software (C3745-IK9S-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 17:42 by xyz
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
ISDN-POOL-RTR uptime is 3 week, 4 days, 10 hours, 41 minutes
System restarted at 10:21:59 IST Sun Aug 1 2010
System image file is "flash:c3745-ik9s-mz.123-26.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 3745 (R7000) processor (revision 2.0) with 111616K/19456K bytes of memory.
Processor board ID JPE080313AA
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
62 Serial network interface(s)
2 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31360K bytes of ATA System CompactFlash (Read/Write)
This is an alignment error followed by a correction. How often are you seeing this error? Is it disrupting service? Can you post a 'sh log' ?
u1kumar2002
     As per my understanding... This is a log output for a spurious access. Plz check the document. It is related to software.
http://cisco.biz/en/US/products/sw/iosswrel/ps1828/products_tech_note09186a00800a65d1.shtml
Uttam
http://www.startnetworks.blogspot.com/
