RV120W - Performance and speed, kill session
schwarz1967
Hallo,
I have problem about performance or speed with the RV120W VPN router. I have change the Hardware, (same with the same firmware) is the same problem. When I have a Remotedesktop session, he says, that the  connection break.
I have change th hardware to a Linksys router, with this hardware works it fine. I have a QSC Sync 2MB cable.
Have any other the same problem ?
vragotha
Level 3
Level 3
  Are you trying to RDP to a device behind the router? Can you post the error it lists for the disconnect reason? Have you tried using VNC to see if it works instead of RDP?
Hi Michael -- Please see my post on your other thread. Will you please help us troubleshoot by sharing your configuration file?
Stephanie Reaves
Small Business Technology Group
