Allow a Few Websites
Create Share
Hi!
I need to allow only a few Internet websites from Cisco 1841 Router for my LAN users. What Access-List should be used for this. Can somebody give me some examples or links?
Thanks!
lal.antony
Hi Create Share,
Just to be clear you just want to allow access to some selected website and block the rest? Please state what websites you want or give me an example on how you want to go ahead with this and I can provide you with simple access-lists to give you the solution you require.
Cheers
Lal Antony
CCNA, CCNP
www.lalantony.com
I have this configuration. I need to allow some clients to access some websites like hotmail, gmail, cnn, bbc.
Thanks!
Building configuration...
Current configuration : 2472 bytes
version 12.4
hostname Branch
boot-start-marker
boot-end-marker
enable password password
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp pool Branch
   network 192.168.1.0 255.255.255.0
   netbios-node-type h-node
   default-router 192.168.1.2
   dns-server ISP DNS Server
ip name-server ispns1
ip name-server ispns2
vpdn enable
vpdn ip udp ignore checksum
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
username password
interface FastEthernet0/0
ip address public ip
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.2 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered FastEthernet0/1
peer default ip address pool Branch
no keepalive
ppp authentication pap chap ms-chap
no keepalive
ip local pool Branch 192.168.1.241 192.168.1.250
ip classless
ip route 0.0.0.0 0.0.0.0 Public IP
no ip http server
ip nat pool ovrld Public IP prefix-length 30
ip nat inside source list 102 pool ovrld overload
ip nat inside source static tcp 192.168.1.99 3389 interface FastEthernet0/0 3389
access-list 102 permit tcp 192.168.1.0 0.0.0.255 host Server1 IP eq 3389
access-list 102 permit tcp 192.168.1.0 0.0.0.255 host MailServer IP eq 443
access-list 102 permit ip host 192.168.1.91 any
access-list 102 permit ip host 192.168.1.92 any
control-plane
line con 0
password password
login
line aux 0
line vty 0 4
password password
login
line vty 5 15
password password
login
end
Do you get web access at all through this, just wondering if the NAT is done properly. Please advice.
Lal Antony
www.lalantony.com
I have seen examples where you have a small,"black list" of web sites that you want to block using NBAR and class maps. See below
http://ardenpackeer.com/qos-voip/tutorial-how-to-use-cisco-mqc-nbar-to-filter-websites-like-youtube/
I haven't seen an example however where by default you block the majority of sites and only allow a "white list" of authorised sites. Potentially that configuration would become quite complex where you block each web site in turn and allow others.
Please remember to rate all posts that are helpful.
