Allow Internet traffic from vlan
Dea.Loro
I have different vlan configured under FastEthernet 0/0 on Cisco Router 2801
vlan50 connected to new switch, and configured probably, but the devices with vlan50 can't access internet, so I need to allow internet access from vlan 50
interface FastEthernet0/0.50
description voice vlan
encapsulation dot1Q 50
ip address 10.50.100.1 255.255.255.0
19 Replies 19
Jaderson Pessoa
Does your router has a nat configuration for this VLAN?
Jaderson Pessoa
*** Rate All Helpful Responses ***
luis_cordova
Hi @Dea.Loro ,
Start with this:
1- Verify that vlan 50 is included in the trunk connection that the switch communicates with the router.
2- Verify that the router has a default route, pointing to the interface that gives you internet access.
3- Verify that the network associated with vlan 50 is included in the nat.
4- Verify that inside the subinterface f0/0.50 you have configured the command ip nat inside.
Please see attached running config. I changed couple of settings for security reasons.
Hello, do this settins, please.
ip nat inside
ip nat pool Voice 10.16.12.248 10.16.12.248 netmask 255.255.255.0
ip nat inside source list 50 pool Voice overload
ip nat inside source list 5 interface Serial0/2/0 overload
access-list 50 permit ip 10.150.44.0 0.0.0.255 10.2.4.0 0.0.0.255
access-list 5 permit ip 10.50.100.0 0.0.0.255 any
and check connections.
Jaderson Pessoa
Excellent, I will try it next week, and keep you updated. We have internal policies related to network changes, and i have follow them
your access list 50 doesn't look right, as the destination is not 'any' (the Internet), but 10.2.4.0/24.
Make the changes marked in bold:
version 12.3
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname 2801
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret ?????????????????????
clock timezone CDT -6
clock summer-time CDT recurring
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
aaa new-model
aaa authentication login default local
aaa authentication login vtymethod group tacacs+ line
aaa authentication login conmethod line
aaa authentication enable default group tacacs+ enable
aaa authentication ppp default none
aaa authorization config-commands
aaa authorization exec default local group tacacs+ none
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
ip subnet-zero
ip cef
ip dhcp excluded-address 10.16.12.1
ip dhcp excluded-address 10.16.22.250 10.16.22.254
ip dhcp excluded-address 10.16.22.248
ip dhcp pool phones
network 10.16.12.0 255.255.255.0
option 150 ip 10.2.4.4
default-router 10.16.12.1
dns-server 8.8.8.8 8.8.4.4
ip domain name domain.com
ip multicast-routing
no ftp-server write-enable
voice-card 0
ccm-manager redundant-host 10.2.4.5
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.2.4.4
ccm-manager config
username tah privilege 15 password 7 ?????????????????
username Cisco privilege 15 password 7 ????????????????
username CTS password 7 ?????????????????????????
class-map match-any AutoQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-any AutoQoS-VoIP-Control-Trust
match ip dscp cs3
match ip dscp af31
policy-map AutoQoS-Policy-Trust
class AutoQoS-VoIP-RTP-Trust
priority percent 70
class AutoQoS-VoIP-Control-Trust
bandwidth percent 5
class class-default
fair-queue
buffers small permanent 100
buffers middle permanent 150
interface Tunnel0
description Backup to ????????????
bandwidth 768
ip address 10.151.1.134 255.255.255.252
tunnel source FastEthernet0/1
tunnel destination ??.??.??.252
interface Loopback0
ip address ??.???.???.1 255.255.255.248
description INFO
no ip address
ip route-cache flow
duplex auto
speed auto
interface FastEthernet0/0.2
description Voice VLAN
encapsulation dot1Q 2
ip address 10.16.12.1 255.255.255.0
ip pim sparse-dense-mode
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 10.150.44.250 255.255.255.0
ip nat inside
interface FastEthernet0/0.4
description DMZ (Public) VLAN
encapsulation dot1Q 4
ip nat inside
ip nat inside
interface FastEthernet0/1
description Backup Interface
ip address 10.24.24.5 255.255.255.252
duplex auto
speed auto
bandwidth 1536
ip address 10.300.207.2 255.255.255.252
ip nat outside
service-policy output AutoQoS-Policy-Trust
encapsulation ppp
load-interval 30
auto qos voip trust
ip local pool pptp 192.168.1.10 192.168.1.20
ip classless
ip route 0.0.0.0 0.0.0.0 10.300.207.1
ip route 10.16.12.0 255.255.255.0 10.300.207.1
ip route ??.???.??.252 255.255.255.255 ??.??.??.?85
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip pim bidir-enable
ip pim autorp listener
ip mroute 0.0.0.0 0.0.0.0 10.300.207.1
ip nat inside source list 1 interface Serial0/2/0overload
ip tacacs source-interface FastEthernet0/0.2
access-list 1 permit 10.50.100.0 0.0.0.255
snmp-server community Voice11 RW
tacacs-server host ??.??.??.?58
tacacs-server host ??.??.??.?4
tacacs-server timeout 2
tacacs-server directed-request
tacacs-server key 7 ?????????????????
control-plane
rmon event 33333 log trap AutoQoS description "AutoQoS SNMP traps for Voice Drops" owner AutoQoS
rmon alarm 33333 cbQosCMDropBitRate.1060.1055 30 absolute rising-threshold 1 33333 falling-threshold 0 owner AutoQoS
line con 0
exec-timeout 240 0
login authentication conmethod
line aux 0
line vty 0 4
login authentication vtymethod
transport input ssh
line vty 5 15
transport input telnet ssh
ntp clock-period 17178224
ntp server 216.239.35.0
end
Why you put the nat for "interface FastEthernet0/0.3" ?  I need it only for interface FastEthernet0/0.50
Type. Remove ip nat inside from that interface...
Curious to know if you get it to work....
rsrs keep calm ^^
Jaderson Pessoa
Didn't work. Used IP Packet and found an issue with routing. Keep getting "unroutable"
*Feb 25 18:38:31.643: IP: tableid=0, s=10.50.100.1 (local), d=10.50.100.150 (FastEthernet0/0.100), routed via FIB
*Feb 25 18:38:31.643: IP: s=10.50.100.1 (local), d=10.50.100.150 (FastEthernet0/0.100), len 56, sending
*Feb 25 18:38:31.643:     ICMP type=3, code=1
*Feb 25 18:38:31.967: IP: tableid=0, s=10.50.100.1 (local), d=10.150.44.45 (FastEthernet0/0.3), routed via FIB
*Feb 25 18:38:32.642: IP: s=10.50.100.150 (FastEthernet0/0.100), d=8.8.8.8, len 84, unroutable
*Feb 25 18:38:32.642:     ICMP type=8, code=0
*Feb 25 18:38:32.642: IP: tableid=0, s=10.50.100.1 (local), d=10.50.100.150 (FastEthernet0/0.100), routed via FIB
*Feb 25 18:38:32.642: IP: s=10.50.100.1 (local), d=10.50.100.150 (FastEthernet0/0.100), len 56, sending
*Feb 25 18:38:32.642:     ICMP type=3, code=1
10.150.44.45: Internal AD Server
access-list 1 permit 10.50.100.0 0.0.0.255 any   <  change from 1 to 5 this access-list.
Thanks in advance.
Jaderson Pessoa
I just found that Serial0/2/0 Interface is down. I think the voice system is getting Internet from different interface
Didn't work, so i ran debug ip packet and keep getting "unroutable"
Attached the latest config file
You applied wrong acl on nat configuration. Please just run this command below;
access-list 5 permit 10.50.100.0 0.0.0.255 any
Jaderson Pessoa
