Unable to access SSH via management interface Cisco router 4331
stephennoel
Hey all, I'm trying to do SSH to my router via management interface but it is not working, it doesn't work via same network or if connected directly.
5 Replies 5
Leo Laohoo
crypto key generate rsa modulus 4096
There is absolutely no problem with SSH access via VTY lines.
If SSH works ok for vty then it certainly is not a question about whether SSH is properly configured. If SSH works to vty but does not work to management interface then it suggests that there is some other issue, perhaps the management vrf does not have a route to the subnet where you are originating SSH?
Rick
Rick
Hello
Be easier if you posted th
If applicable, Could you post the config of the router in question, could a various reasons why it isn't working
Kind Regards
Paul
interface GigabitEthernet0
vrf forwarding Mgmt-intf
ip address 10.10.X.X 255.255.255.0
negotiation auto
end
Configuration for mgmt interface;
There is no problem with SSH access via VTY lines.
