allow local network to access public internet address on DMZ
smithcolm
I have a Cisco ASA 5510
I am using ASDM 6.1
I have a LAN and a DMZ and an internet connection.
I am using one of the internet connection IPs to host a HTTP service on a server in my DMZ.  (its the same interface as my internet connenction but a different IP to the one used for internet connectivity)
so say my LAN is 192.168.1.x
and my DMZ is 172.168.1.x
I can access DMZ from Lan and vice versa.
when i try to access the public IP (or URL) from a pc in my LAN i get nothing.
I have enabled DNS rewrite (doctoring) but it is still not working.
the HTTP service is available from other sites.
thanks
C
smithcolm
I figured it out.
I actually needed to use "Hairpinning"..
I setup a static NAT rule that nat'd the internal HTTP server to the external IP but on the inisde interface.
so something like
static (DMZ,inside) outsideIP DMZ_ServerIP netmask 255.255.255.255
