internet access problem with ipsec & nat
johan.lorier
I have the following problem.
Situation:
- one main location M, with ASA5510 (v8.3) which has many (about 100) ipsec tunnels to remote locations. Local subnet is 172.16.254.0/24
- some of these remote locations have the same subnet, let's say there are 2 locations which use 192.168.1.0/24
- for one of such location (let's call it A), I create a 'virtual subnet' 192.169.1.0/24 which is a static nat in the router on the location: ip nat inside source static network 192.168.1.0 192.169.1.0 /24 no-alias. This location has a Cisco 881 router.
The problem is that with this NAT configuration, internet traffic on the location A is not possible.
Question: what is the best way to solve this?
dot11 syslog
ip cef
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto ipsec transform-set ipsec_tun_cybercenter esp-3des esp-md5-hmac
crypto map CMAP 1 ipsec-isakmp
set peer x.x.x.x
set transform-set ipsec_tun_cybercenter
match address 105
ip ssh version 2
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
pvc 2/32
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description LAN Interface
ip address 192.168.1.253 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
no ip mroute-cache
interface Dialer0
ip address negotiated
ip access-group 106 out
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username kpn password 7 082A5C40
crypto map CMAP
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 101 interface Dialer0 overload
access-list 101 deny   ip 192.169.1.0 0.0.0.255 172.16.254.0 0.0.0.255
access-list 101 permit ip 192.169.1.0 0.0.0.255 any
access-list 105 permit ip 192.169.1.0 0.0.0.255 172.16.254.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
XIE YAO
"ip nat inside source static network 192.168.1.0 192.169.1.0 /24 no-alias"
Perhaps you can try with a policy nat (static nat + route-map) to let nat kich in only for IPsec.
Let's know if it can solve the issue.
5 Replies 5
XIE YAO
Thanks, i will try it and post the results.
Just to confirm that my thoughts are right, this would be the solution:
route-map STATIC_RMAP permit 1
match ip address STATIC_NAT_ACL
ip access-list extended STATIC_NAT_ACL
permit ip 192.168.1.0 0.0.0.255 172.16.254.0 0.0.0.255
ip nat inside source static 192.168.11.2 192.170.11.2 route-map STATIC_RMAP
This would nat only the traffic that is going to the ipsec tunnel. Is this right?
Johan,
First, for better understanding, this link describles the difference between access-list approach and route-map approach.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml
And I have labed this scenario in GNS3, it worked with below configuration.
Here R2 is for IPsec, R3 simulates internet, with a loopback interface 8.8.8.8
Configuration:
PC:
PC(config)#do sh run
Building configuration...
Current configuration : 798 bytes
version 12.3
hostname PC
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
ip domain name lab.local
no ip dhcp use vrf connected
no crypto isakmp ccm
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R1:
R1(config)#do sh run
Current configuration : 2011 bytes
version 12.3
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
crypto isakmp policy 10
crypto isakmp key cisco address 8.8.123.2
crypto ipsec transform-set TS esp-3des esp-sha-hmac
crypto map CM 10 ipsec-isakmp
set peer 8.8.123.2
set transform-set TS
match address vpn
ip address 8.8.123.1 255.255.255.0
ip nat outside
duplex auto
speed auto
crypto map CM
interface FastEthernet1/0
ip nat inside
duplex auto
speed auto
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 8.8.123.3
ip route 172.16.0.0 255.255.255.0 8.8.123.2
ip nat pool 169 192.169.1.0 192.169.1.254 netmask 255.255.255.0
ip nat inside source route-map tointernet interface FastEthernet0/0 overload
ip nat inside source route-map toipsec pool 169
ip access-list extended vpn
permit ip 192.169.1.0 0.0.0.255 172.16.0.0 0.0.0.255 <- match after natted source
access-list 101 permit ip 192.168.1.0 0.0.0.255 172.16.0.0 0.0.0.255
access-list 111 permit ip 192.168.1.0 0.0.0.255 any
route-map tointernet deny 10
match ip address 101
route-map tointernet permit 20
match ip address 111
route-map toipsec permit 10
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R2:
R2#sh run
Current configuration : 1208 bytes
version 12.3
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
crypto isakmp key cisco address 8.8.123.1
set peer 8.8.123.1
match address vpn
interface Loopback0
ip address 172.16.0.1 255.255.255.0
ip address 8.8.123.2 255.255.255.0
duplex auto
speed auto
crypto map CM
no ip http server
ip classless
ip route 192.169.1.0 255.255.255.0 8.8.123.1
permit ip 172.16.0.0 0.0.0.255 192.169.1.0 0.0.0.255
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R3:
R3#sh run
Current configuration : 815 bytes
version 12.3
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip domain lookup
interface Loopback0
ip address 8.8.8.8 255.255.255.0
ip address 8.8.123.3 255.255.255.0
duplex auto
speed auto
no ip http server
ip classless
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
When PC ping to IPSEC destination, on R1:
*Mar  1 01:28:57.179: NAT*: s=192.168.1.2->192.169.1.1, d=172.16.0.1 [130]
*Mar  1 01:28:57.291: NAT*: s=172.16.0.1, d=192.169.1.1->192.168.1.2 [130]
*Mar  1 01:28:57.351: NAT*: s=192.168.1.2->192.169.1.1, d=172.16.0.1 [131]
*Mar  1 01:28:57.371: NAT*: s=172.16.0.1, d=192.169.1.1->192.168.1.2 [131]
*Mar  1 01:28:57.391: NAT*: s=192.168.1.2->192.169.1.1, d=172.16.0.1 [132]
*Mar  1 01:28:57.419: NAT*: s=172.16.0.1, d=192.169.1.1->192.168.1.2 [132]
*Mar  1 01:28:57.439: NAT*: s=192.168.1.2->192.169.1.1, d=172.16.0.1 [133]
*Mar  1 01:28:57.459: NAT*: s=172.16.0.1, d=192.169.1.1->192.168.1.2 [133]
*Mar  1 01:28:57.479: NAT*: s=192.168.1.2->192.169.1.1, d=172.16.0.1 [134]
When PC ping to 8.8.8.8, on R1:
*Mar  1 01:28:31.659: NAT*: s=192.168.1.2->8.8.123.1, d=8.8.8.8 [120]
*Mar  1 01:28:31.695: NAT*: s=8.8.8.8, d=8.8.123.1->192.168.1.2 [120]
*Mar  1 01:28:31.743: NAT*: s=192.168.1.2->8.8.123.1, d=8.8.8.8 [121]
*Mar  1 01:28:31.799: NAT*: s=8.8.8.8, d=8.8.123.1->192.168.1.2 [121]
*Mar  1 01:28:31.839: NAT*: s=192.168.1.2->8.8.123.1, d=8.8.8.8 [122]
*Mar  1 01:28:31.863: NAT*: s=8.8.8.8, d=8.8.123.1->192.168.1.2 [122]
*Mar  1 01:28:31.883: NAT*: s=192.168.1.2->8.8.123.1, d=8.8.8.8 [123]
*Mar  1 01:28:31.903: NAT*: s=8.8.8.8, d=8.8.123.1->192.168.1.2 [123]
*Mar  1 01:28:31.923: NAT*: s=192.168.1.2->8.8.123.1, d=8.8.8.8 [124] *Mar  1 01:28:31.659: NAT*: s=192.168.1.2->8.8.123.1, d=8.8.8.8 [120]
HTH.
Static nat + route-map did solve my problem, thanks for your input.
