Allow network reachability to vrf interface over OSPF
Kenneth Goh
Please help, what configuration is required so that I am able to ping from R3's
192.168.0.2 to R2's interface Gi1
that is running in
VRF INET
with IP address
192.168.1.1/30
Thanks in advanced.
Hi @Kenneth Goh ,
Please add the following to R2:
ip route 192.168.0.0 255.255.255.252 192.168.2.1
This should fix it.
19 Replies 19
M02@rt37
Hello @Kenneth Goh,
I don't understand the two
default routes
on R3 and R4.
Best regards
You may ignore the
default routes
if it is not required , how can the objective be achieved?
Ok @Kenneth Goh,
Please share outputs of
#sh ip route
command for all 4 routers.
Add R1
#sh run
please.
Thanks.
Best regards
balaji.bandi
As Long as R1 and R2 routing ok with VRF aware OSPF confiuation
that should be reachable (still an issue) - post
show run
all the devices and
show ip route, show ip ospf neigh
Other note why do you need to 2 Static routes in R3 and R4 ? if you want to only
172.x.x.x network
to be used bnetwen R3 and R4 you need more specific router rather static route any.(i know you added some value 10 in each side).
BB
Giuseppe Larosa
Hello @Kenneth Goh ,
just to understand the link between R1 : GE2 and R2:GE2  is in the global routing table or it is in the
VRF INET
in the first case you have an issue, also that link has to be in
VRF INET
in order to build a VRF lite end to end connectivity.
Of course, there is little else we can say until you add the config on the routers in txt attachement files as noted by others.
Hope to help
Giuseppe
The link between R1 & R2 (both interface Gi2) is in the global routing table while both R1 & R2 (both interface Gi1) is in
vrf inet
Infact there isn't much configuration to share, please help provide any configuration change to make it work, you need not have to use ospf. Thanks
Harold Ritter
Hi @Kenneth Goh ,
The simplest would be to configure the R3 -> R4 -> R2 path with static routes as follow:
R3:
ip route 192.168.1.0 255.255.255.252 172.16.0.2
R4:
ip route 192.168.0.0 255.255.255.252 172.16.0.1
R2:
ip route vrf inet 192.168.0.0 255.255.255.252 192.168.1.2
On R3, you can then ping 192.168.1.1 source 192.168.0.2
If you wanted the traffic to go through the R3 -> R1 -> R2 path, you would need to configure a tunnel between R1 and R2 with the tunnel source and destination in the global routing table (GRT), put this tunnel in
VRF inet
and configure the appropriate static routes. Another option would be to configure MPLS between R1 and R2 (more work but more fun).
For R3 -> R1 -> R2 path would route leaking alone work?
For option 2, upon configured tunnel interface, I am not sure about the routes to add.
R1#sh run int tunnel 1
Building configuration...
Current configuration : 142 bytes
interface Tunnel1
vrf forwarding inet
ip address 10.0.0.1 255.255.255.252
tunnel source 192.168.2.1
tunnel destination 192.168.2.2
R2#sh run int tunnel 1
interface Tunnel1
vrf forwarding inet
ip address 10.0.0.2 255.255.255.252
tunnel source 192.168.2.2
tunnel destination 192.168.2.1
Lastly for option 3, please help elaborate more, my understanding is to just enable mpls on Gi2 on both R1 & R2?
Hi @Kenneth Goh ,
Good point. This would work too.
For path R3->R1->R2 with the tunnels, you would need the following static routes.
R3:
ip route 192.168.1.0 255.255.255.252 192.168.0.1
R1:
ip route vrf inet 192.168.1.0 255.255.255.252 10.0.0.2
R2:
ip route vrf inet 192.168.0.0 255.255.255.252 10.0.0.1
For this option, you need to enable LDP between R1 and R2, configure a route distinguisher (RD) and route target (RT) for R1 and R2, run MP-BGP (VPNv4) between R1 and R2, redistributed connected and static in BGP for the inet VRF. As I mentioned before, this is a bit more complex than the other options.
Hi @Harold Ritter
For R3 -> R1 -> R2 path route leaking, below is what I did, not sure why is it not working?
R1#sh run | in ip route
ip route 192.168.2.2 255.255.255.255 GigabitEthernet2
ip route vrf inet 192.168.1.0 255.255.255.252 192.168.2.2 global
R1#show ip route vrf inet | in S
S 192.168.1.0 [1/0] via 192.168.2.2
R2#show run | in ip route
ip route 192.168.2.1 255.255.255.255 GigabitEthernet2
ip route vrf inet 192.168.0.0 255.255.255.252 192.168.2.1 global
R2#sh ip route vrf inet | in S
S 192.168.0.0 [1/0] via 192.168.2.1
R3#traceroute 192.168.1.1
Tracing the route to 192.168.1.1
VRF info: (vrf in name/id, vrf out name/id)
1 192.168.0.1 4 msec 12 msec 8 msec
2 * * *
Hi @Kenneth Goh ,
Try the following instead:
R1:
ip route 192.168.0.0 255.255.255.252 GigabitEthernet0/1
ip route vrf inet 192.168.1.0 255.255.255.252 GigabitEthernet0/0 192.168.2.2
R2:
ip route 192.168.1.0 255.255.255.252 GigabitEthernet0/1
ip route vrf inet 192.168.0.0 255.255.255.252 GigabitEthernet0/0 192.168.2.1
Hi @Harold Ritter
Still no luck, by the way I change
GigabitEthernet0/0 to GigabitEthernet2 and GigabitEthernet0/1 to GigabitEthernet1
instead as both R1 & R2 do not have interface
GigabitEthernet0/0 and GigabitEthernet0/1
R1#show run | in ip route
ip route 192.168.0.0 255.255.255.252 GigabitEthernet1
ip route vrf inet 192.168.1.0 255.255.255.252 GigabitEthernet2 192.168.2.2
Routing Table: inet
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.0.0/30 is directly connected, GigabitEthernet1
L 192.168.0.1/32 is directly connected, GigabitEthernet1
192.168.1.0/30 is subnetted, 1 subnets
S 192.168.1.0 [1/0] via 192.168.2.2, GigabitEthernet2
ip route 192.168.1.0 255.255.255.252 GigabitEthernet1
ip route vrf inet 192.168.0.0 255.255.255.252 GigabitEthernet2 192.168.2.1
R2#show ip route vrf inet
Routing Table: inet
192.168.0.0/30 is subnetted, 1 subnets
S 192.168.0.0 [1/0] via 192.168.2.1, GigabitEthernet2
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/30 is directly connected, GigabitEthernet1
L 192.168.1.1/32 is directly connected, GigabitEthernet1
1 192.168.0.1 4 msec 8 msec 8 msec
2 * * *
Hi @Kenneth Goh ,
Can you please provide a
show ip route
for the global routing table (GRT) from both R1 and R2?
Hi @Harold Ritter
R1#show ip route
S 192.168.0.0 is directly connected, GigabitEthernet1
192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.2.0/30 is directly connected, GigabitEthernet2
L 192.168.2.1/32 is directly connected, GigabitEthernet2
R2#show ip route
S 192.168.1.0 is directly connected, GigabitEthernet1
L 192.168.2.2/32 is directly connected, GigabitEthernet2
