Allow polling of Cisco switches
dpkelly999
I need my Cisco switches to be polled by Castlerock SNMP software. Currently the switches do not return any information, however, 3rd party active equipment can be polled by the same Castlerock SNMP software
My questions are:
1) What are the commands to allow my switches to be polled by the Castlerock SNMP sofware?
2) I have 2 switches: Catalyst 3650-24-TS-S and Catalyst 2960CX-8TC-L. What are the commands specific (if required) for these two switches?
balaji.bandi
You need to configure snmp configuration
https://www.manageengine.co.uk/products/oputils/enable-snmp-cisco-router.html
BB
what do you have currently configured for SNMP on both switches ?
Below is a sample:
2960(config)# snmp-server community public
2960(config)# snmp-server enable traps
2960(config)# snmp-server host 192.168.1.1 version 2c public
With this, your CastleRock SNMP server (192.168.1.1 in this example) should be able to poll anything using the 'public' SNMP community. Obviously you want to use another community than that, for security reasons...
Hello
Basic snmp polling and sending of traps:
conf t
access-list 10 permit x.x.x.x <---caslterock host
snmp-server host x.x.x.x Private
snmp-server community Private rw 10
Kind Regards
Paul
The reason that you are able to poll other devices automatically is because they are using the default SNMP strings of public for read only access and private for read/write access.
your monitoring software has these default values built in.
To enable SNMP read-only access version 1 or 2 for you cisco gears see the following.
From the config#  prompt enter   snmp-server community mysnmp-password RO  [ replace  mysnmp-password with your customized password]
Cheers
****Rate All Helpful Posts****
P.Williams
