Allow to NAT'ed hosts to talk via external IP (using ASA 5520)
jason.harper
Hello!
I have two hosts behind an ASA on a private network.  Both hosts are NAT'ed (each has a unique public IP).  I need Host A to be able to talk to Host B through their respective external IP's.  How do I achieve this?
Thank you!
5 Replies 5
andrew.prince
Level 10
Level 10
Are you takling about DNS resolution of the outside NAT IP address?
Correct.  There's an application running on Host A that does a look up for Host B and it uses the external IP for Host B.  They can of course communicate with one another on the private interface but I also need them to be communicate with one other across the public interface.
OK - DNS Doctoring or DNS rewrite as it's known.  See the below url
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/inspect_basic.html#wp1350877
HTH>
Thank you!  Ok, I've enabled this and now when I do an nslookup from Host A for Host B, it correctly gives me the internal IP instead of the external IP.
However, if I try to ping Host B by name or navigate to the website that Host B is running using the DNS name, it still tries to go to the external IP.  Am I missing a step?
Thanks!
I think I just solved. Had to enable the inspect maps for ICMP and HTTP along with DNS and not seems to be working!
