Allow traffic from a VLAN to communicate with only the router
josephnunham
I'm sure this is a simple answer, but I can't seem to find one that sounds like a positive solution. I have two VLANs set up on a Catalyst 2950 switch: VLAN 1 (192.168.1.x) and VLAN 2 (192.168.2.x). VLAN 2 can ping the router on the 192.168.1.x network and nothing else, which is what I want. However, computers on the 192.168.1.x network can ping computers on VLAN 2, which is what I do not want. I want to make it where VLAN 1 and VLAN 2 cannot communicate with one another, but that VLAN 2 can still ping the router on VLAN 1. I've read about access control lists and ip tables, but which one is the definite solution?
Thank you for your guidance.
lgijssel
Level 9
Level 9
This must be achievable with access lists.
regards,
Leo
Hi Leo,
Could you tell me how they are possible in the 2950? I read some places that since it is a L2 device it does not support ACLs.
Thank you.
kishorecisco
It should be possible using an ACL and also try to use distribute list.
regards,
kishore
