Alternate Option For CISCO 3945E
Mayur.Lad
Hi All,
We need to replace Cisco 3945E router (L3 Switch) with upgraded version of Another Cisco product within a same price range.
Can you please provide some information or Alternatives for the same.
Leo Laohoo
upgraded version of another Cisco product within a same price range.
The entire statement is an oxymoron.
Any Cisco product which is an upgrade of a previous version is, a minimum, 30% more expensive than the previous version.
What is the reason for upgrading the 3945E?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Some of the 4xxx series might be in the same price range.
HI Joseph,
Thanks for your reply.
I am considering Cisco 4451 router for up-gradation from C3945E and just wanted to know that whether Cisco 4451 is compatible with HWIC-2FE modules or not?
I want atleast 5 Routed interfaces for the connectivity on the node.
Kindly revert.
Mayur
