Am I doing static PAT correctly?
gmtimmons
I have a series of security cameras I have been asked to nat, but with limited public IP's I am going to have to use nat.
requirements are camera 1 using tcp inbound port 1024, camera 2 using port 1025, etc
Do I just need these static commands to make this work:
hostname (config)# static (inside,outside) tcp outside_ip 1024 insided_ip 1024 netmask 255.255.255.255
hostname (config)# static (inside,outside) tcp outside_ip 1024 insided_ip 1025 netmask 255.255.255.255
etc
there are about 10 cameras total
fyi, I have nat configured and working for other items such as webservers, etc.
thanks in advance
18 Replies 18
What is the default gateway on these devices? Are they pointing to the
firewall?
NT
hmmmmmmm  great question... I think the camera guys set them up with the internal gateway, not the firewall...
.so you think it could be a routing issue?
Most likely that could be the issue because your configurations look good.
Please check the default gateway and see if we can somehow point it to the
ASA or route the traffic to ASA.
NT
thanks to all..... it was a routing issue....  wrong gateway used by mfg's setting up the devices    working now
