Analog phone with Ethernet Network
husseinmuneer
Dear Sirs,
Could you please help me to find the best solution for the attached scenario.
I have 2 sites these 2 sites have analog telephone lines and the 2 sites want to call each other but the link between them is Ethernet link ( MAN).
If you have a solution please inform me.
Muneer
muneer@yemen.net.ye
Giuseppe Larosa
Hello Muneer,
you would need to deploy two voice gateways that can be Cisco IOS routers with FXS ports and appropriate IOS image and feature set.
The two routers can have the phones connected to the FXS ports and then can call each other using VoIP IP dial peers.
Hope to help
Giuseppe
